| examples of (classed) yachts using bladder tanks We plan to use bladder tanks to store jet fuel. We have a rather compact area available and in order to create the required coffferdam space and make it inspectable, bladder tanks are the solutin. I was told by a L/R surveyor that it's not uncommon to use bladder fuel tanks, especially on GRP. One of the main concerns for L/R is that the tank maintains its shape regardless of how full it is so the connections to the tank can be fixed (versus some kind of flexible hose configuration. I've already been told about materials that can be used to accomplish this and can be removed (remember, the bladder tank must be removed to inspect the surrounding cofferdam space) but I wonder if anybody here knows of yachts using bladder tanks which can eventually lead me to some manufacturers that have experience with this kind of (custom) setups. Thorwald
__________________ ----------------------------------------- www.expeditionyacht.org The ultimate expedition yacht conversion |
| There have been several systems around in the 80ies (Vetus sold one too) but I could´nt find one left when I searched one year ago. I would like to have such system too (and the cofferdam), but had no success by so far. Partially filling is the problem with all the systems I found. Let me know when you find one. Regards Richard |
| perhaps rubber boat makers? |
| Hi Ward, Richard, It's not so much the tank material. There are plenty of bladder fuel tank fuel manufacturers but none list any specific expertise with ships and none is certified by any class society. That's OK. They will simply have to be tested against leaks which is not a problem. The issue is keeping the tank from collapsing when it's empty. I've been pointed to these people and this application - http://www.crestfoam.com/news14.html - and am waiting for their reply. The material is called: "Explosion Suppressant Foam" and if you Google it, you find more websites like this one here http://www.customfoams.co.uk/cf/cont...oducts/esf.htm although they are using the material produced by Crestfoam. Seems like something that could work. Thorwald
I´m completely confused now. Collapsing is what the tank has to do! (Not the cofferdam, I hope). That is the only advantage I can see, no need for baffles in a conventional metal built space (tank). Just one or two "liners" inside the tank and tere is no free surface to cope with. The foam stuff would make it impossible to inspect the tank space inside!? |
| in aircraft the bladders are laced to the structure to keep their shape unlaced to remove |
| No Richard, L/R does NOT want the tanks to collapse when emptied because they don't like the concept of flexible hoses to connect the ventilation and fuel filling piping. So using this foam material we should make pieces that can be located inside the tank to keep it up while still be removable. Basically combination of colums and beams made from foam, held in place by some place holders made from the same bladder tank material.
| Yes, yes, I know that is the prob! They do´nt like all the wishy washy stuff. And for some understandable reason, that did wear out soon and unpredictable. But now I´ve got the idea with the foam, sounds possible. But cost? We are talking quite several m³ in both of our vessels. Btw. where did you end with your cost calculations? I assume we both came to the same result? Richard |
| Well, we're talking about 3 m3 per tank so it's not like huge. Of course, I have no clue yet how expensive this material is but we probably don't have to fill the tank completely. Say a flat 'ceiling' part supported by 6 40x40 cm 'columns' might do the trick but that's something we'll have to calculate. At any case, an interesting "problem" to solve. Thorwald
| they solved the problem in aircraft decades ago |
| yes and i have done it i would refer you to the ch-47 fuel nacelles as one example of an attached bladder |
| Whats that wardd? It would be really a great help to find a proven solution. |
The problem of sloshing is still there, unless you use multiple bags, each in its own stiffened cell, and connected to the bottom manifold. |
| How far out is classed as the ocean? | djwkd | Open Discussion: All Things Boats & Boating | 164 | 04-22-2007 02:08 AM |
| the shipyard’s first ice-classed research-type yacht. | bbsboat | Boat Design | 3 | 11-10-2006 10:27 AM |
| Fuel Bladder (Military Issued) | jas4906 | Marketplace | 1 | 03-04-2006 11:22 AM |
| Some examples of Boat design | alvaromatos | Boat Design | 0 | 12-31-2003 10:08 AM |
| Latex Bladder | turnershells | Boatbuilding | 0 | 01-20-2003 01:38 PM |
