Old 02-22-2006, 06:43 AM
Rep: 700 Posts: 3,208
In the US the cheapest source of a good diesel is removed from a refrigerated truck.
The Kubotas and Yanmar takeouts are 2 or 3 cylinder and cost $300 or so US$ , complete & running.
Many don't have that much time in hours , and would be quite reliable for a launch.
The drive/ reduction could be handled bu simple belts , 3 belts will handle 30hp , far above this boats requirements.
Sounds like any heat from a radiator could be used to advantage in your climate!
5 hp per ton of displacement is the MAX most non plaining boats can ever use.
FAST FRED
Old 02-22-2006, 01:42 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
Trouble is Fed we don't get many Yankee 'reefer' trucks in the western isles (some of the islands are smaller than the trucks!) Plus of course the guy needs to be able to get a payload into the boat, by the time you gets all yer bits and pieces in there's not a lot of room for much else! (after all it is rumoured that an American machine cannot operate without a coke machine attached - in some cases its part of the main article!!
Ballast Converted Steel Lifeboat Peter Large Metal Boat Building 17 03-29-2005 02:29 PM
Lifeboat mold wanted Antonie Bogert Boat Molds 3 01-19-2005 03:22 PM
hull of an open lifeboat Jeroen Fiberglass and Composite Boat Building 1 07-01-2004 12:08 PM
Ship's foto. Dim Boatbuilding 0 09-11-2003 04:47 AM
Building a better Lifeboat Portager Boat Design 2 06-10-2002 11:13 PM
