#31
| So what.. as I said, another implement (whatever the name) and the aerodynamic principle and outcome is the same.. |
#32
#33
The info " Exhaust gas from the engines power a downstream steam turbine, which drives the four Enercon-developed Flettner rotors" makes me think the steam turbine (small motor) is directly driving the rotors, so the heat from the exhaust is creating the steam for the steam turbine ( not gas turbine). I reckon the primary source of rotation is the steam turbine, while the *energy source* is the heat from the gasses. Certainly, there is no risk of exhaust back pressure problems using this process, as another contributor was concerned with Last edited by rwatson : 08-29-2010 at 07:21 PM. Reason: extra info |
#34
| It would seem to me that the structure of the rotors especially if they rotate would have to be substantial considering the forces acting on it to propel the boat. So the amount of weight and high cg may affect boat in some undesirable ways. I would not want to be out in a storm with them. How do you drop the sails? I believe the kite-sail idea is much more flexible and safer. Perhaps inflatable rotors could be develop that can be deflate if winds exceed a certain amount. |
#35
For those interested v.d velden has recently introduced an application for the flettner rotor as (bow)rudder: http://www.vandervelden-marinesystem...DEFINITIEF.pdf greetings Tackwise |
#36
One cannot drop masts, so, the argument is mute. The power to make them rotate is not very much, btw. And to answer another question, how many of these systems are built. There have been at least two dozen of them in the past 30 years. All have shown the system works as assumed. One correction of my statement about the rotor on Cousteau´s boat: He decided to install the original Flettner Rotor on Calypso, and that was all I did know about. Here a sketch of the old plans: ![]() I was not aware that his successors developed another (derivate) system. Regards Richard |
#37
The Coandă effect occurs over any smooth surface or flow plane, while the Magnus effect only occurs over a smooth rotating cylinder. ------- I have been trying with some effort to imagine anything that a Flettner rotor would be good for. The only advantage I can see it has is that since it is symmetrical (from above) it doesn't need to ever be aimed into the wind at all. That omnidirectional ability takes a big toll on overall efficiency, however. The practical problem it has is that since the propulsive force it generates is always perpendicular to the prevailing wind (think about that limitation for a moment!) it is only ideal for crosswinds, and would be much less useful with the wind in any other direction. If you just think it's interesting from a scientific standpoint, I understand that. From a geek standpoint, I like the idea of running my house off solar panels,,,, but I know enough to know that for most people (including myself) it's not really economical to do, compared to the boring old way of just paying to get electricity from a wire hooked to my house. If you think it is a grand solution that's vastly more efficient than anything else out there, then ignore the fact that after 88 years no airplane company, windmill company or most boat companies are keeping the lights on by building the things, and go ahead and build yourself one--but don't get too surprised when kids on Hobie cats and lasers run circles around you. Because I would bet very much that they will (and even at that, they're gonna tell you it's not a sailboat, too...). ~ |
#38
you don´t understand it. (and I am not wasting my time to elaborate on it) What I do not understand is why you are fighting against a well proven concept, with really childish arguments? Your Hobie cat will not run circles around a 200 meter ore carrier, be sure! Regards Richard and: http://www.google.com/images?q=flett...w=1024&bih=607 |
#39
| I have been fascinated by Flettner rotors for years, it is very interesting to see some coming in to use. There is a good source of information here by someone who spends less time wondering about things and more time actually doing them: http://www.rotorboat.com/ It is worth taking some time to understand some of their unique features like no need for trimming and 'self reefing' properties as windspeed increases. I have long been of the opinion that they would be an elegant solution for a sailing river launch, able to take full advantage of gusty, shifting, inland breezes. If powered from a solar panel I see no reason why this should not be considered 'sailing'. |
#40
Here is a link to a small rotor boat. Apparently it points VERY well and uses very little power. http://www.rotorboat.com/ ![]() Quote:
#41
No end plate, the rotor can't propels, since the difference of pressure is sliding away on the top. The rotor is conical, can't have any propulsive effect. Doesn't make sense. I don't think it is what he want us to see. A rotor will not make the boat heel. Perhaps the windage on a very high wind can have a heeling effect, that I don't know. But I can be wrong. Daniel |
#42
| Na mate. Its certainly a Flettner rotor type of propulsion. There are even sailing vids and theory pages. You should read the page. He came up with this idea independently from his studies in aviation. He only found out later that this had already been applied to ships. Going by his report the idea scales all the way to RC boats too as he developed an RC boat first. The magnus effect is what curves a balls flight in the air when hit with a spin, so it would surely work on a sightly tapered tube if it works on a sphere. There is no need to have an end plate for it to work. My guess is he chose to taper the tube instead of use an end plate to reduce the vortices's of the top of the mast. It appears to work quite well. If he not heard of the Flettner rotor ships before he dreamt up this idea I am sure he would have used a straight tube with an end plate too. That is the beauty of not having preconceived ideas to cloud your mind from other possibilities which may be valid. (did I just sound like questor?) ![]() |
#43
| Fletter Math Calcs Quote:
In the interest of the topic, I am posting three scans of actual formulae that perports to to calculate the propulsive force of a rotor. Its been some years since I immersed myself in the study, but hopefully my rough notes wont obscure the text. If anyone needs to have indecipherable bits resent, pleaselet me know. |
#44
| It does indeed have a rotor on this artists impression, but I am positive that the boat that Coustea ( not Calypsos successive owners) visited the USA in had the large chord wing masts, as I vividly remember a documentary on it. |
#45
| Rotor Physical Performance in Storms, and Kite/Sail Use Quote:
Regarding perfomance at sea, I attach two scans of documents based on the actual results of the Buckeau at sea, Remarkably, the vessels stability performance actually improved with the rotor conversion as graphed at the top of page 78. Some points to regard - 1) Page 77 "At 40 to 60 mph wind velocity , the wind pressure is not any greater than at 25 to 30 mph. This represents a tremendous advantage .... over ordinary sail." 2) top of page 78 - "when the rotor is shut down, the wind pressure is far less than that of (standard) rigging, even after the sails have been removed" (see graph of Buckeaus stability curves) Note that "reducing sail" on a rotor ship is a matter of reducing the motors throttle, which is done in seconds. Compare that to the compexities of either Kite Sail or standard rigging. For those who find the concept of powered aerodynamic devices a bit strange, consider the illustration of a modern jet wing. True, the lifting surface does not rotate, but the engines force high velocities of air over a curved surface due to the velocity of the crafts forward movement. Because a boat is unable to achieve the velocities needed to generate lift across a stationary surface, Mohammed goes to the mountain, and speeds up the lifting surfaces to achieve the propulsive effect desired. So, in some sense, as a sailboat is like a glider, a rotor ship is like a powered airplane. |
| Spirit Of Balto Launched | alaskatrawler | Metal Boat Building | 9 | 10-15-2010 03:33 AM |
| Ship with 2 screw | mkovac67 | Boat Design | 0 | 04-06-2007 09:09 AM |
| Free ship | alpamis34 | Boat Design | 3 | 02-02-2007 09:48 AM |
| Armand Rousso launched X3D Technologies Corporation. | eager | Education | 1 | 04-03-2005 08:11 AM |
| Better Freedom Ship | Dook | Boat Design | 5 | 03-13-2005 07:00 PM |
