| That is not the case, the Flettner rotor is very efficient. And the rotation is provided by the exhaust gas of the diesels! |
Take some vise-grips and crush the end of your car's exhaust pipe down to about 50% restriction, and see what it does for your gas mileage. ------- My main question is how much power s really necessary for spinning such a device. Why not put some kind of wind-operated turbine on top of the Flettner rotor, and let the wind spin the thing too? ~ |
And thanks, I must not destroy my exhaust, I know what back pressure causes. In the example linked to by rwatson, the losses are zero, the expansion of the gas** provides the power to spin the rotors. Otherwise wasted energy. Regards Richard edit: **and conversion into electricity |
The pressure differential was achieved by opening the holes in the leeeward side of the lifting surface, and using fans to suck air into the mast itself, thereby creating a negative pressure differential. Re the "Tracker" info, I have searched online for articles, to no avail over the years. In the spirit of preserving the information on line, I have taken the liberty of photycopying the article for all to review. I am sure that after over thirty years that the magazine would appreciate the publicity. Also , as a point of interest, I have also included an image of a Flettner Windmill that was built and working - to help demonstrate that smaller scale rotors will work. In my bones, I feel that with the modern, precision technology of today (especially with carbon fibre/resin technology) , that rotors have real potential to provide a usefull role for many wind assisted vessels. |
| Scale of Sail V Rotor Quote:
It has intrigued me no end over the last forty years. PS. I have added an illustration from the original study done on rotor sail designs Last edited by rwatson : 08-29-2010 at 01:16 AM. Reason: add illustration |
| Thanks for the article! |
Your link: http://www.oldsaltblog.com/2010/08/1...nally-arrived/ |
#25
| The Flettner rotor is a solution in search of a problem. ......It is most certainly not a sail, if it needs engine power to function--it is only a method of converting engine power. ......If it generates seven times as much as an airfoil the same size, they why is it not used on any production aircraft, or as the propulsion method for any aircraft? I've seen a number or articles about experimental models, but for some reason all those dumb guys over at Airbus and Boeing keep sticking with the same old airfoil wings (-and airfoil engines...). ......DIY boatbuilders are free to try anything they want, and yet there's a sizable list of other innovations that are far more common than Flettner rotors: Kort nozzles, winged keels, keel bulbs, hydrofoils, rigid-wing sails, torpedo tubes and variable-pitch props to name just a few. Other than this publicity stunt by Enercon, the original Flettner boat and the Cousteau boat, how many Flettner-rotor boats even exist? I'd bet not very many, compared to anything else in that list. .....I've no doubt the principle works, but it's not as useful as inferred. Enercon themselves doesn't even make any wind turbines using Flettner rotors. ~ |
#26
| But it is.. thou a bit different implement with a blower instead of rotating the tube.. |
#27
| I would strongly recommend to study the topic before you make yourself a clown. Especially the Magnus effect is the point you are missing. Wind turbines are not ships, they don´t sail either. Enercon knows that. Regards Richard |
#28
Wikipedia says the NOTAR system uses the Coanda effect, as the tail boom of the MD-500 does not revolve. The Magnus effect is a property of boundary layer flows around a rotating tube. -------- The Flettner rotor is 88 years old; when modern industry with its engineers and accountants won't touch an invention that is well into the public domain, that tells you pretty much all you need to know about its usefulness. Has the Flettner rotor gained widespread use in any industry? For any purpose? ~ |
#29
| does anyone have a graph showing the force and DIRECTION of force relative to incident wind as a function of rotor speed? I also thought of the Cousteau wing in connection with this. Would pulling suction on a small forward area of the rotor help to keep the lift aligned with the ship as apparent wind changes? What about a "peeler" to control aft separation and influence thrust direction? searching "Magnus effect" seems to get better stuff than "Flettner" |
#30
In the past 80 years NOTHING was brought really further related to wind power in our industry. That does not prove it is the wrong way. The Flettner rotor has proven it does what it is expected to do, saving a lot of fuel. That was valid in 1925 and it is still today. The fact that YOU don´t like it, does not make any difference. Most probably you don´t like it because you don´t understand it. In the years when Flettner developed it, nobody in the shipping world was interested in wind power. The fuel (coal) was dirt cheap and the steamers replaced the tall ships in these days. Everybody was going "modern". Times change, and we see several new attempts to reinvent the wheel. In this case that is not necessary, it is already there. BTW Albert Einstein was a true admirer of Flettners Rotor, maybe he had a better understanding of the system: ![]() |
| Spirit Of Balto Launched | alaskatrawler | Metal Boat Building | 9 | 10-15-2010 03:33 AM |
| Ship with 2 screw | mkovac67 | Boat Design | 0 | 04-06-2007 09:09 AM |
| Free ship | alpamis34 | Boat Design | 3 | 02-02-2007 09:48 AM |
| Armand Rousso launched X3D Technologies Corporation. | eager | Education | 1 | 04-03-2005 08:11 AM |
| Better Freedom Ship | Dook | Boat Design | 5 | 03-13-2005 07:00 PM |
