| European rules for a small boat builder... Hi, I am designing small boats, say 3 or more meters. I also want to build a few for clients. I have tried to understand what I might have to do in regard to ISO and CE rules and regulations, but it looks like a ton of work and costs. There are a lot of small boat builders in Europe I would guess. How do they do this? Any concrete instructions, etc. would be much appreciated!!! Grant |
| Grant, for such small boats certification is simple and can be done by testing. One needs to arrange Owner's Manual, GA drawings; check-lists will be filled by inspector. Stability and flotation tests would be required; scantlings are not required. Actually there are few options. The procedures are presented in RSG guidelines. |
Requires a free registration before consulting and downloading the documentation. |
| The CE certification is pretty straightforward. There are several options given for testing or meeting standards. You can also provide alternate means of meeting standards.
__________________ Gonzo |
| Thanks all, there are a ton of documents there...and versions... any pointers to the key ones I should look at. Also I see that I still would need to go to a local CE certification authority... any idea how much they would charge for a one off boat, built for sale? |
| Smallish vessels like you intended can be "self certified" by the manufacturer.. |
| European boat diesel ventilation | RoyHB | Diesel Engines | 16 | 06-13-2011 08:29 AM |
| looking for designer and builder for small recreational boat | marcostdo | Services & Employment | 7 | 04-20-2011 12:20 AM |
| European Designers of Small Cruising Powerboats | rsmartin | Boat Design | 0 | 08-13-2010 10:54 PM |
| European yacht charter rules? | gp333 | Open Discussion: All Things Boats & Boating | 26 | 07-01-2010 09:55 AM |
| small motorboat / regulation and rules | max | Boat Design | 12 | 12-11-2003 04:02 PM |
