| Estimating Power I am currently trying to estimate power for a project vessel. It is a 65 meter displacement motor yacht. So far I have estimate Admirality Coefficients from SOTA data and browsed through Harvald diagrams, but am still looking for an alternate method of estimating power(shaft). Anyone have suggestions? |
| Can you post a drawing of the hull lines, together with some more data - main dimensions, estimated displacement, propulsion type (for SHP), etc.? |
| the whole design is still very preliminary. what i can get you is: LWL = 57m BWL = 11.2m draught = 3.2m estimated dis. = 1100 tonnes Cb = 0.48 Twin Screw |
| What is the speed target? Is that loaded displacemnt?
__________________ Gonzo |
If you consider a 1100T displacement vessel with WL of 57m then attached curve will give you an idea of the power to push the hull at various speeds. Depending on how well it is propped, appendages and windage the shaft power could be around double that shown for any required speed. Take this as indicative. If you have an actual hull shape then the analysis should be done on that not some hypothetical hull. Rick W |
| jmercer Your target speed is what is required. Since your length displacement ratio, is not overly excessive, roughly 5.5, hence the hull is not that "draggy". However are you trying to estimate the EHP naked, or the total power requirements, taking into account losses (mechanical and hydrodynamic) etc to arrive at a total installed power required to go XX speed? |
| Why don't You ask the designer - he should know! And if he doesn't, then I wouldn't trust him to design a ship like this!
__________________ Best regards, Søren Flening NOTE: This post is a natural product. The slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects. |
| hmm, I think I may have been too brief with my request. I'm not looking for numbers. This hull is hypothetical. I'm looking methods of finding a preliminary power estimate, not the actual estimates. |
| In that case, apart from the methods you have already tried, read the excellent and now classic paper "Some ship design methods" by Watson and Gilfillan, published in RINA 1976. Has all you'll need. |
There are quite a few references to GODZILLA on the forum. Rick W |
| You're missing the point again Rick, as always. He is not looking for numbers, which you like. He is looking for ..methods of finding a preliminary power estimate, not the actual estimates... This means words and equations and theory and understanding where the theory comes from and why. Numbers are simply an output and irrelevant. Plugging "whatever" into a computer program does not answer his Q. If it were that simple, he would just select 4 or 5 software programs that perform resistance calculations! That isn't rocket science.....anyone can do that. It would do you good too, to put down your endless computer programs and try and do the same as jmercer. |
| Thank you for all the input. I ended up reading back through a resistance and propulsion book from Harvald and came up with a few methods. Im still trying to get my hands on that RINA paper, the library at my institution is looking into it. Thanks again |
| jmercer ...if you can't get the RINA paper just PM with your email. I have it electronically, but it is some 12MB, so cant email via this website. |
![]() Cheers Daniel |
| For a yacht I have always used power/displacement. Compare a boat/hull with numerous known vessels (more the better) and soon you will observe what other people think is correct power loading. Consider the differences in hulls, speeds and applications. Some yachts operate at 2hp per ton .. what I consider a minimum for boats that aren't extreme in some way. I think 3.5 to 4.5 hp per ton is very close to perfect but you will find many (perhaps even a majority) that are well above that. Frequently manufactures over power their boats for marketing reasons. It's hard to tell people that are accustomed to 200hp in an automobile that 70hp is enough to power their 16 ton boat. When comparing avoid commercial boats that do not have a fixed load and sailboats. Easy Rider |
| Steel Estimating Software | steelsoftw12 | Boatbuilding | 0 | 01-06-2009 06:20 AM |
| Estimating LCG | Clinton B Chase | Boat Design | 2 | 01-06-2008 07:50 AM |
| Theories for estimating bulb drag | Dan S | Sailboats | 19 | 10-11-2006 10:23 AM |
| estimating the resistance of a submarine | amirhosein | Boat Design | 0 | 04-25-2005 02:59 AM |
| estimating displacement | dionysis | Sailboats | 2 | 02-16-2003 12:56 AM |
