Old 05-30-2006, 10:24 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2069 Posts: 3,574
Originally Posted by frank marsden
...I have just started on a containerable motor sailer with a potential variety of roles. This will be good looking...
I'd appreciate you posting some images at 'Containerable motorsailer' thread, if possible.
About this thread: I firmly believe boating is a matter of dreams. And what is nice for ones, may be ugly for others...
Old 05-30-2006, 11:02 PM
MAINSTAY's Avatar
MAINSTAY MAINSTAY is offline
Rep: 24 Posts: 60
I am considering a lanteen rig on a wishbone mast, reason, to be able to lower the mast quickly, easily, single handed on a boat about 8m loa.2.1m beam.
I had a lanteen rig on a Malibu outrigger (6m). It was a fast rig. As I recall, the mast was 13-ft (10-ft above deck) and we just lifted it out of its pocket at the end of the day. The gaff was 27-ft and could be quickly and easily lowered for overhead obstacles, not that we had any.
There seems to be a myth that a wishbone mast or bipod mast is easy to raise and lower, and a single mast is not. I suggest that the windage is not worth the benefit, particulary when a single mast is easily lowered with proper placement of the shroud chainplates. A bipod mast is easy because it has its pivots aligned and the two masts provide lateral support to each other.
It's easy enough to to get the lateral support by aligning the hole in each shroud chainplate with the maststep hinge. On many boats this puts the top of the chainplate above the rail, as high as the doghouse on some boats.The support required during lowering can be provided by adding a diagonal chainplate or using a pair of chainplates in an inverted V. If the chainplate holes are aligned a little aft or below the step pivot, the tension in the shrouds will be relaxed a little, but can still be adequate for control of the mast during lowering.
Larry
Old 05-31-2006, 01:49 AM
Mayfly Mayfly is offline
Banned
Rep: 23 Posts: 65
The design imparted and imprintment of the artist soul, infused and emerged as the essense of yacht
Troller Yachts vs Trawler Yachts Greenseas2 Boat Design 163 01-18-2012 11:48 PM
Tanton Yachts LeoinSA Boat Design 1 04-14-2006 09:05 AM
Mega Yachts Richard Petersen Boat Design 0 02-07-2005 07:26 PM
aluminium yachts lazeyjack Sailboats 2 03-21-2004 12:44 PM
J Class Yachts Boat Design 1 10-16-2001 12:29 AM
