Old 02-09-2003, 06:42 AM
micael micael is offline
Rep: 10 Posts: 11
Epoxy in hull
Hi !
I have an idee to build a design using Epoxy, the problem I have for the moment is calculating the thickness of Epoxy needed for the design.
Dose any one of you have a link or some information regarding how to calcualte needed thickness ? ( sandwish design)
Thanks in advace !
Br
Micael
Old 02-09-2003, 07:13 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
Epoxy in hull
did you read http://www.boatdesign.net/articles/foam-core/index.htm or are you planning self foaming the components? yyou may also try "epoxy" in a search. what design, size and building method are you thinking of?
yipster
Old 02-09-2003, 08:51 AM
ErikG's Avatar
ErikG ErikG is offline
Rep: 344 Posts: 397
Hej Micael jag svarar på engelska för alla andra...
Since the Epoxi is the glue you first need to concentrate on how much reinforcement you need to use. This is totally dependent on boat size, type of construction and materials used. How much epoxi you'll need to use depends on what and how much reinforcements you use.
Please specify what you want to do and what type of boat it is.
Before even considering construction, make sure the design is ok and that you recieve all the needed information for scantlings from the designer.
Speaking of the designer, he (or she but not very likely) should be able to give you all the info you need for a reasonable fee.
Snart är det vår
Erik
Old 02-09-2003, 12:49 PM
Rep: 10 Posts: 11
HI and thaks for your answers !
I will look into this and retund with new questions.
Br Micael
Erik, good look with your new hose !
Old 02-09-2003, 01:07 PM
ErikG's Avatar
Rep: 344 Posts: 397
Just to clarify for the rest of u!
I just bought a house and have no trouble with the old hose...
Erik
How about boat design definitions JonathanCole Boat Design 55 01-24-2010 04:48 PM
Luhrs T-29 (1995) diesel inboard converted to outboard Iya Boat Design 13 03-07-2007 06:48 PM
Jet Drive Jet Drives 15 12-18-2006 09:51 AM
Paint System For Epoxy Hull VIKING Boatbuilding 5 02-02-2005 03:02 AM
Stepped Hulls Ryon Macey Powerboats 53 08-01-2004 10:44 AM
