| epoxy to gel coat bonding i have built a cabin on my 40 foot crab boat (material- system three epoxy,9oz coth tape at all joints and corners,10oz coth over fir ply. the boat is hand layed glass poly resin and gel coat Question how well will epoxy and coth bond to sanded and cleaned gel coat where new cabin meets hull. |
| We normally grind the color gelcoat off, to a uniform line, sometimes formed by taping a straight edge for this job, and then wipe it down with acetone, to clean it good. This will allow for less work in the finish part of the job. We also place a fillet of thickened resin along the joint, made up with 404 thickening agent, from West System. We have also layed it up with the 403 fibers, if you plan on glassing it while the resin is either in the green stage or just as the fillet is firming up. When Robbins, on the bay, and many other fiberglass builders were selling the bare hulls, we would build the cabins from plywood and glass, and installed them this way, at the washboards. Find you some 10 0r 12 ox biaxall for the job, and cover it with the finish tape for the ease of finish work. Layer it while the biaxall is wet. |
| Bonding Aluminum with Epoxy | Chris Krumm | Materials | 49 | 02-10-2012 05:16 AM |
| milky patches in clear gel coat | still afloat | Fiberglass and Composite Boat Building | 3 | 07-22-2005 04:29 PM |
| Gel Coat vs Fiberglass | pramdx | Fiberglass and Composite Boat Building | 6 | 07-18-2005 07:44 PM |
| Epoxy over Gel coat troubles | tropicrows | Fiberglass and Composite Boat Building | 4 | 02-28-2005 07:56 PM |
| Life span of gel coat | Materials | 0 | 12-24-2002 03:52 PM | |
