| Enlarging an existing design Some years ago I produced plans and a building manual for an eleven and a half foot Norwegian pram. Jacques, a Belgian woodworker, built one of these and liked it so much he wants to build a 5-meter (16 foot) version--about a 30% increase. I'm not sure how to advise him and thought there might be somebody out there with the necessary experience? Please keep your comments concise as I may forward them directly to Jacques. Simon Watts |
| I'll leave this one to you Paul... |
| A 30% enlargement is just too much to expect from the laws of mechanical similitude and comparison (relativity). It would be kind it everything scaled up nice and uniform, but it's not the case and things quickly get out of hand. It would be your best advise to select a design of the size (volume) he actually needs, possibly one that needs just a little "tweaking", say less then 10% in length difference from the original, certainly no more then 15%. Scaling down America Junior plans? In this thread it's discuss it in a little more detail. |
| simon do you mean straight forward scale up by 30%?...in naval architectural terms, a geosim? If you keep everything the same, then scaling up by 30% is easy, you just multiply all your linear dimensions by 1.3. BUT, your volume will increase by 1.3^3 = 2.2, this is a significantly larger boat, being more than twice the displacement. Unless of course that is what you want. Perhaps better narrow down what you really mean by 30%, or just geosim up (scale) a bit, then as PAR noted above, just tweak it slightly, ie increase length uniformly etc etc |
| Scaling Try this excel spreadsheet hjs
__________________ www.sassdesign.net I'm not lost, I'm just uncertain of my position. I'm still confused, but on a higher level |
| If you designed the boat why is it so difficult to design another longer? Strech the station spacing by 30% , increase the freeboard a bit and re-fair the lines
__________________ Gonzo |
| As Gonzo points out, if you designed one and it worked well, it shouldn't be too complex a job to design something similar a bit bigger. The Barkla scaling factors, applied to your original hull, should produce a shape with comparable performance in a somewhat larger (or smaller) size. Of course, the vessel's scantlings will have to be re-calculated for the greater loads encountered in a larger hull.
| Adding extra chines to existing design | unseen wombat | Boat Design | 5 | 05-29-2009 04:54 PM |
| "Advanced Hull Speed" design new & Upgrade existing watercrafts | AmnonMikeCohen | Open Discussion: All Things Boats & Boating | 29 | 06-23-2008 04:00 PM |
| Legality of “Borrowing” Lines from Existing Hull Design | CET | Boat Design | 55 | 02-04-2006 08:26 PM |
| Newbie working with an existing design | salty__dog | Boat Design | 11 | 01-20-2004 09:17 PM |
| Looking for software with short learning curve to alter existing design | Buzzard | Software | 12 | 12-14-2003 10:33 PM |
