Old 03-09-2006, 08:54 AM
BarendG BarendG is offline
Rep: 10 Posts: 2
Engine Spacing?
I am currently designing a trimaran and need to decide how narrow I can make the center hull.
Obviously I want to make it as narrow as possible and I am therefore only limited by the engine width. The boat will be using Twin Mercury Optimax 225’s. I’ve checked all over the net but can’t find information on how close you can put twin motors together, HELP!!!
Mercury also doesn’t supply dimensions for the engines, anyone have a clue how wide these babies are?
Old 03-09-2006, 02:19 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
using two OB i figger you can make the transon bracket wider than the hull
with two IO you can place one a little in front of the other to save beam
Old 03-09-2006, 09:59 PM
bhnautika bhnautika is offline
Rep: 499 Posts: 489
welcome to crap marketing by the engine manufactures. You might find something on this site supplied in a previous forum
http://www.marinepower.com/download/dosearch
Old 03-09-2006, 11:38 PM
Rep: 499 Posts: 489
this might be ok
Old 03-10-2006, 04:37 AM
Rep: 10 Posts: 2
Thnx
Thnx a mill guys, I'll see what I can do!
Replacing an outboard engine with an inboard engine boere Sailboats 1 09-16-2005 08:49 AM
automotive engine -> marine engine???? mechanical314 Boat Design 2 08-02-2004 09:47 AM
1) Are hulls same shape in a Cat 2) hull spacing Will Boat Design 7 05-05-2004 11:41 AM
ABS Shell Longitudinal Spacing Boa Boat Design 10 05-01-2004 06:02 PM
Replacing an outboard engine with an inboard engine boere Boatbuilding 0 06-23-2003 05:21 AM
