Old 06-29-2005, 11:13 AM
Thomas Johnson Thomas Johnson is offline
engine set back
I have a 1999 wellcraft 25 ft walk around with 200hp johnson. I want to install set back for engine. Has anyone done this and do you have any recommendations as to which bracket to use.
Old 06-30-2005, 02:14 AM
kmorin kmorin is offline
Rep: 230 Posts: 185
outboard placement
TJ, are you mounting a Gil type bracket that moves the engine off the transom aft? If so the advantage is that the CG moves aft and the top end can move up a tad. The engine can be moved up in relation to the bottom's aft edge at the transom. The wake rises aft the hull about an 1" (or slightly more) for a foot aft. So the engine can be raised in relation to the stern many are almost a yard long so the top of the engine mount moves up nearly 3".
Several bracket makers offer single and duals which might allow you to carry a 'get-home' smaller kicker if you feel the need. The bracket makers are the real pros here, they're the ones with the experience and that's who I'd ask about your hull and engine combo.
Cheers,
kmorin
TP52s mighetto Sailboats 2052 09-06-2007 11:46 AM
gearboxes and potential bobber Boat Design 38 04-03-2005 12:22 PM
Propeller sizing and engine loading E4ODnut Props 3 12-29-2004 05:50 PM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 04:06 AM
