Old 01-04-2011, 11:08 AM
Alfonso Alfonso is offline
Rep: 68 Posts: 40
Engine price/output
Hello!
Can anyone help me with some literature or references on marine diesel engine prices relatet to power output? Let's say $/kW.
Thank You in advance!
Old 01-04-2011, 11:54 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,251
To obtain serious answers you have to add at least the power range you are looking for. Other important considerations are rpm and type of injection.
Old 01-04-2011, 12:06 PM
Rep: 68 Posts: 40
Only thing I know is the range... 300-3000 kW.
Old 01-08-2011, 08:13 AM
JRMacGregor JRMacGregor is online now
Rep: 245 Posts: 78
Recent quote for medium speed (less than 1000 RPM) 32cm bore turbo engine package (true marine diesels) in the 3000kW output range;
- Euro 350 per kW for the inline engines
- Euro 300 per kW for the Vee versions
if you go for higher speed (more than 1000 RPM) and less output the ratio will be less - perhaps by a factor as much as 1.6.
Old 01-08-2011, 08:29 AM
Rep: 68 Posts: 40
Thank You very much!
Old 01-08-2011, 12:06 PM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
Too damn much,
Old 01-08-2011, 01:42 PM
viking north viking north is offline
Rep: 727 Posts: 1,161
OOO Ya, Christ the last two Volvos 3cyl. 29hp with hurth transmissions I installed in customers boats were over the $10,000 range each. This is not to knock Volvo'S prices as all the manufacturers seem to be in the same range.Be nice to see a price comparison listed on a thread here on the forum which might create a price war and realistic prices. Geo.
Old 01-08-2011, 08:26 PM
Yellowjacket Yellowjacket is offline
Rep: 292 Posts: 249
Smaller engines are cost less on a $/kw basis than big engines. It isn't the same, you need to narrow your range.
seakeeper output sirhamid Stability 2 01-17-2010 02:48 AM
HulWiz output problems BlackSnow Software 0 10-16-2009 09:34 PM
KW output question Delta OnBoard Electronics & Controls 21 08-10-2007 09:00 PM
Engine progress and price control cyclops Propulsion 18 06-20-2005 08:48 AM
Combine Power output or not? Inerested Powerboats 3 08-15-2002 01:19 PM
