Old 04-29-2008, 04:52 PM
bayratt bayratt is offline
Engine Cover Rebuild - Sundeck style
I have a generic vinyl coated full width (about 50 inches deep) engine hatch that has just completed rotted out. The gas lifts supported a lot of weight because once I removed them this thing weighed a ton. The only support is around the perimeter, so I'm assuming whatever I use has to be pretty strong, but what is the best suggestion to limit weight for rebuilding this thing? It looks like originally 3/4 or 1 inch plywood was used.
When water-skiing or hanging out everybody walks on it to get from swim platform into the boat (which really irritates me - any ideas for that?). I'm wondering if building support on each side of the engine might be a good idea to be able to use thinner material for the cover.
Old 04-30-2008, 04:16 AM
Rep: 2891 Posts: 8,798
Your engine box lid has a difficult job to do. It has to keep lots of heat in, noise too, plus it has to be self supporting when it's 100 outside and 250 inside, tolerate people standing and walking on it, all while retaining it's shape, not sagging under the savage life it leads.
This is a pretty tall order for a simple engine box lid.
Plywood was used for several reasons, but the two biggest are; pound for pound it's stronger then steel (amazingly enough) and it's relatively cheap, plus it's easy to work with. A regular wonder material, though like my in-laws, it too can have issues, which you've discovered.
I'm not sure what hatch configuration you have on you boat, but if it's as I suspect, you'll have a great deal of trouble spanning the distance and depth of your compartment with a light weight, yet strong substitute that can provide the same attributes.
Since your only support is around the edge, you should consider an angle or box tubing frame work (maybe aluminum), with some athwartship ribs to stiffen things up, yet remain light. Then skin this will a marine grade of 1/4" plywood (the good 5 ply stuff, not the Lowe's/Depot 3 ply junk). You can screw it to the ribs and the perimeter frame work, which will make both much stiffer. Closely space ribs can replace the much thicker plywood of the previous hatch.
Cover this with a 1/8" or 1/4" foam pad, then vinyl over that, stapling to the plywood underneath. Of course you'll want to install sound proofing and heat insulation, both available at marine stores like West Marine (bring you first born, they may ask). You can't have too much insulation, but you sure can have too little (okay, maybe you should bring along a second child).
If you could post a picture or two, it would be helpful. The boat year, make and model will also be useful.
Old 04-30-2008, 12:10 PM
Mild Bill Mild Bill is offline
Well, not entirely mild.
Rep: 11 Posts: 31
http://www.keypoint.com.au/~skeptics/Bed_of_Nails
Engine Compartment Cover Scotts Fiberglass and Composite Boat Building 3 07-29-2006 11:39 AM
Engine Compartment Cover Scotts Boat Design 1 07-28-2006 07:04 PM
Runabout engine cover LKJR Materials 6 03-13-2006 07:38 PM
46' Sundeck Yacht ChinaYacht Fiberglass and Composite Boat Building 0 12-16-2004 03:44 AM
stiffness question for engine cover hot for teacher Boatbuilding 14 10-28-2003 05:33 PM
