Old 06-26-2005, 07:18 PM
Silent Eater Silent Eater is offline
Electric Outboards?
Greetings, this is my first posting. I live on an electric only lake. And I'm wanting the most hp for my 21 foot pontoon. I'd like to know where to purchase an eCycle with the counter rotating props. Or if there is a better solution. Thanks,
Old 06-27-2005, 12:52 AM
JonathanCole's Avatar
JonathanCole JonathanCole is offline
imagineer
Rep: 58 Posts: 436
Don't know about eCycle with counter rotating props but heres a few places for electric outboards.
http://www.qis.net/~jmgraham/resrun.htm
http://www.outboardelectric.org/index.html
http://www.rayeo.com/motors.htm
Hope this helps.
Old 06-27-2005, 11:30 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Coaxial counter-rotation is probably not going to help you much, I'd think. The main reason for this type of setup is to cut down on side thrust on sterndrives, for better handling. For what you want I'd think you're after a single, large-diameter/low-pitch prop. The ones Jonathan mentions above look like a good place to start.
Old 06-28-2005, 06:04 AM
Rep: 700 Posts: 3,208
With as much wetted surfacebelow and hull above the water , you might need 2 motors of 24 volt to go into a breeze.
FAST FRED
Old 07-24-2005, 11:15 AM
Filmdaddy Filmdaddy is offline
Rep: 10 Posts: 72
Check out the Glen-L site. I don't have the address right now, but I know they have plans for building your own electric outboard for cheap like borscht. Seriously fun project!
Old 07-24-2005, 10:13 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
Remember! Each gear set reduces the power at the prop. A motor that drives the prop directly with the right sized prop is best. Plus a neutral and reverse.-----------------You are asking for a large heavy electric drive to move that much boat and people. Borrow smaller gas motors till you find the smallest hp that does the job you need. Post back with the make and HP. We can then give a real power size in electric. " Lead Sleds " forever.
Diesel outboards and jetboat engines coming Propulsion 39 04-01-2007 05:19 PM
Concept electric drive duluthboats Propulsion 46 07-08-2005 08:27 PM
MV Phoenix - Electric Lobsterboat lockhughes Propulsion 21 06-07-2005 03:25 PM
Electric motor revolutionizes catamaran sailing Jason Stevens Motorsailers 0 05-11-2004 09:10 AM
Twin electric outboards Catfish Boat Design 2 09-22-2003 04:23 AM
