Guest625101138
Previous Member
- Joined
- Jan 20, 2007
- Posts
- Reaction score
- 84
I have been doing some performance testing of electric boat components.
I am using one of my more stable pedal boats and scooter electrics.
The boat is a 6.6m long catamaran made from two length of 142mm aluminium irrigation pipe. It is stable and unsinkable but a bit wet once it gets into waves. It is a good platform for testing propulsion systems.
The drive is a geared 300W scooter motor swinging a 380mm 3-bladed high aspect prop. I have been fiddling with the prop pitch so not exactly sure what efficiency now but it used to be better than 80% in its original application. I use a little scooter variable speed controller with potentiomater speed adjustment. The batteries are two 12V, 10Ah gel VRLA.
I did a 40 minute run today at different speeds into, across and downwind a reasonable breeze in protected water. Distance covered was 3.2km at average of 5.7kph. Top speed recorded was 9.4kph. This was produced downwind with 240W from the battery. The boat would get this speed or better in dead-calm conditions. Attached pdf chart shows speed during test.
I have attached a video showing the boat at 120W giving 6kph and 240W giving just above 9kph.
The 3.2km used approximately 20% of the battery charge so range between 12-15km at 6kph. Less than one hour running at 9kph.
Michlet gives me a power requirement of 110W for 9.4kph on this boat. So overall efficiency is 46%. Motor 78%, prop say 80%, controller 95% - so some unaccounted losses. The testing needs to be done in calm conditions to get more precise data on the hull.
Rick W.
Rick W.
