#91
#92
Your stated objective of getting the prop into undisturbed flow will require you to offset by around 120mm from the hull. This is far more than necessary. You will find 10mm is more realistic. I can watch the development of the turbulent layer down the side of my hull on a calm day and it is not very thick - nothing like 120mm. I place my props with sufficient clearance to avoid then clashing with the hull as they flex the strut in a turn. When I used a rigid strut I cleared by 10 to 20mm. Saving 100mm in draft is worthwhile even on a small boat like this as it enables normal operation close to shore. Being able to lift the prop and still operate is a decided advantage as well. Rick W |
#93
From a reversing point of view you rely on centrifugal force deploying the blades. If this is low relative to the thrust then they will tend to fold backwards. I expect you would get some reverse but it may not be effective. My first attempt will be stainless. I know I can get these to deploy. Rick W |
#94
| Jeremey "...I think we're all coming at this concept with similar interests, but differing backgrounds, which means we'll each put a different weight on certain aspects. As an aircraft designer, I tend to want to build very light, optimise propulsive efficiency as far as practical and go for as clean a hydrodynamic solution as fits with the need for stability and practicality..." I like the colour of your jip!! ![]() I am a naval architect and i design commercial high speed vessels. There are only 3 things that are important about the design of high speed vessels: 1) weight 2) weight and yup 3) weight. Get your weight wrong...and it doesn't matter what programs or assumptions have been made about efficiencies etc...all out the window. Which is why i implore you, for your SOR, to look at the weights in very great detail. As for the hydrodynamics, no real magic there, once the basic SOR has been decided. Hull design is not the black art many try to maintain or claim to be. Hull shape actually has very little influence in the whole scheme of things, it is the length displacement ratio that one needs to concentrate on. Hence the weight being important. Trying to get better juice out of your power unit is great and worth doing, but weight is the biggest killer and will eat up any of your 2 or 5% gain in power or whatever etc very quickly indeed. So money spent on getting the best or latest power units, wiring, etc etc needs to be put into perspective. |
#95
I drew up the Arctic Tern per attached. The bare hull drag is very low under 4kts. From that point it rises very rapidly: 4kts - 42N 5kts - 138N 6kts - 254N The hull has a wetted surface of 3.7sq.m. It will have very clean flow as it is a canoe stern and quite flat. The drag figures listed make no allowance for windage, the drag on the case and drag on the rudder. Making significant allowance for these, a nice round number is 70N at 2.1m/s (say 4kts) for the prop design. You can do the calculations for drag an the various bits once you have details but I would be surprised if they exceed the allowance made in calm conditions. In wind and waves they will rise quite a lot. I have attached the prop design data as well. Of course with the drag being a lot lower than working from an inflated power estimate you can get the prop into more efficient operation. The power level calculated is easily achievable with the small PMSM motors that Jeremy and I have discussed here. Rick |
#96
My reason for optimising the propulsion system is really to do with my desire to run as much as possible on solar power. I really need to keep the electrical power consumption down, so that the percentage power provided by the solar cells is a high as possible. The area I have for these is limited, perhaps around 2mē. At the moment, around 65 to 70% of the displacement is crew weight, so the potential for making a worthwhile reduction in the hull and machinery is modest. I think a good diet might be a better way to go............... Jeremy |
#97
| Jeremy, Have you considered an adaptation of the bion x system. Google bionx and you will see what it can do. I am considering it for assistance to my motorization "hybrid" solar, sails, human, wind & hydro (tide and river currents) (squirl cage or prop), simply said, a bicycle (montain bike) "manual transmission" asssisting and increasing speed and upwind performance. |
#98
| I'm familiar with the Bionx system, as I've already built my own electric recumbent bike (see picture below). The Bionx tries to provide electric pedal assistance, but I'm building a pure electric boat, with no pedals. I did look at converting an electric bike hub motor to drive a big prop, but they tend to be heavy and don't really turn fast enough. Most struggle to do more than 200 rpm, so would need a pretty big prop to work well. Jeremy |
#99
| Rick, Thanks so much for investing your time in the Freeship model to assess speed vs drag. I hope you are more adept than me at Freeship - that would have taken me several hours. Good to hear your confirmation that decent speed is achievable with such modest power. I suspected it as my 25' 2000# launch will go 4.3 kts with 500 watts from the battery which would be around a half hp at the prop shaft.
__________________ Denny Wolfe www.wolfEboats.com |
#100
| What if instead of using a prop, one would use a wheel like pedal boats, the rpm would be less and the shallow depth potential interesting. This is an interesting bike, i see those now and then, they look very confortable especially for men ... the std bikes discourage me ... i tend to use roller skates, for a hockey player it is almost as fast as a bike but more dangerous. Of course this is for slow speed . I was looking at DIY solar photovoltaic panels , accordeon panels for folding, but i had started investigating if the new film thin photo. panels, the company was in Lowel Mass. I have not had time to go further on this, but considering that a 37 ft wide and 60 ft long cat has potential for large areas (not including the inflated pull back raft 30 x 30 ft roof shade). DIY panels are the only viable option for now. With the new led lighting and the new Macs cpus , it looks like my energy demands will be less , hence i look at the economics (pumping back for $ into a USA and at the Quebec elct. power systems) using wind, solar and water. Tidal currents at the spot where we are going to be are 3 to 6 knts (so regular and predictable ...) . The wheel also came up when i looked at an anchorage wind gust preventer system ... still working on the design being that i try to use the same aparatus for many uses. My wife having many uses potential she will be allowed ... she says she knows many uses for me also ... Mike |
#101
It took about 30 minutes. Viewing the linesplan was the hard part. It is not very clear. Not sure if you have seen the latest evolution of my solar-wind hull. I call it a faux-tri as it is a long slender hull underwater, a trimaran on the waterplane to give stability and a reasonably beamy monohull above the water. This is the easiest driven hull I can come up with that has fair accommodation and will do 8kts with less than 1kW. Rick W |
#102
| Rick, I like the idea of your hull design. I'm sure you already know this, but back in the 90's, the research agency I work for built a similar layout as a research ship. It was the brainchild of my director at that time, who spent a lot of effort persuading the powers that be to invest in a technology demonstrator. Here's a link to a short article describing it: http://www.royalnavy.mod.uk/triton/*...3/noRedirect/1 Jeremy |
#103
| Jeremy There are quite a few images of that vessel around the forum. I get the implication from use of the word "but" that it had some problems? Do you care to give details? Rick W |
#104
#105
| The only 'problem' were the paxman's! |
| Electric Boat Design | John Klimek | Boat Design | 42 | 09-05-2011 01:11 PM |
| Need fast, EFFICIENT, commuter boat | MattM | Boat Design | 47 | 05-19-2009 09:39 AM |
| Solar Electric Boat Design | DSGNA | Boat Design | 3 | 03-11-2009 08:44 PM |
| Electric Boat Data | Guest625101138 | Boat Design | 12 | 10-02-2008 07:17 AM |
| Electric boat advice | camglasgow | Hybrid | 3 | 04-07-2006 09:09 AM |
