Porta,
The PWM gives more thrust/watt than the resistor control when both are at full power. The resistor control just directly connects the battery to the motor at its fastest setting so how could the PWM be more electrically efficient than that? That's what bugs me.
My guess is that there is additional resistance being picked up when going through the resistor speed control. This could be due to the switching contacts being oxidized or something involving the reversing switch. The old troll motor models had only as simple double pole double throw reversing switch, and the highest speed feed directly to the motor. Maybe bypassing the resistor switch with PWM eliminates those losses?
This may have something to do with the large losses in the PWM connectors as actual max voltage at the motor is 8.5v with the PWM, 10v with the resistor control, both at max throttle. Hopefully my new connectors will fix this disparity.
With no load I get a voltage drop from battery to motor of 0.2v with resistor, 0.42v with PWM. This shows the PWM is going to 100% power with the throttle pot pegged.
The props are fragile but will be completely protected behind the sail boat's rudder. They are cheap, too, less than $4.00 each. Spares are affordable
Yes on the model props, I have been using these for many years without a single failure, but at 40 watts maximum. You can get them cheap and graduate them to the optimum because of the large number of pitch and sizes available. Sometimes you find something better than what is predicted by computer through experiment. The best way to test is under fly using a knotstick
http://www.knotstick.com/ if you have some clear water. These are very accurate and are even used to calibrate electronic knotmeters, and they don't jump around in their readings.
The internal connectors MK used are the same crappy .25" spade terminals I used on the external wires. The top of the motor gets warm just from the speed control connector resistance. The actual speed control coil is down in the motor under water.
Yes, the coils can be cooled in that way, but there may some slip connectors affecting things down there sometimes.
I get the best prop chosen I will start working to reduce electrical losses.
