Closed Thread
Old 11-05-2011, 04:36 AM
Dan V Dan V is offline
Rep: 10 Posts: 7
effect of close clearance tunnels on gear ratio and wheel selection
I´m looking for advice concerning the effect of close clearance tunnels on gear ratio and wheel selection. I was very dissatified with the performance of a boat I designed with a tunnel. I found research of the late Donald Blount and redesigned the tunnel as per his reccomendations. The boat is 32´ and about 14,000 lbs. Cummins 450C w/ 1.48 gear. Upon relaunch w/ a 22 x 26 four blade (medium cup), the top speed was 32 knots but top rpm was only 2350. Calculations show a slip of only 5%, so the tunnel w/ its .375" tip clearance was doing its job perfectly, but that restriction had to be hard on the engine. So thinking hydrodynamic friction, I started whittling away at pitch, then diameter and back to pitch again. I´m finally down to 20-1/2" x 22" and just am getting 2600rpm at wot. Performance sucks: top speed is 24k, 20k cruise at 2200 and I´m burning 15% more fuel than before. I think I have to go back to filling the tunnel w/ propeller to get the system to work as designed and will need to change gear ratios to protect the engine. How do I determine if I need a 1.79:1 gear, 2:1 or something different? Or is there something else I have overlooked?
Thanks,
Dan Varner
Old 11-05-2011, 05:20 AM
baeckmo baeckmo is offline
Hydrodynamics
Rep: 962 Posts: 631
First: State rated engine power @ rpm, then main dimensions of tunnel, including propeller position.
Old 11-05-2011, 04:01 PM
Yellowjacket Yellowjacket is offline
Rep: 292 Posts: 249
I had a meeting with DLB a few months ago. He was on time for the meeting, so I wouldn't have characterized him as late.....
We all gotta go sometime, but I think your description of him as deceased is premature....
Old 11-06-2011, 04:40 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Gentlemen, I propose to keep this discussion in one place and not spread on several identical threads. This one is evolving well, so why not using just that one: effect of close clearance tunnels on gear ratio and wheel selection.
Cheers
Closed Thread
effect of close clearance tunnels on gear ratio and wheel selection. Dan V Inboards 26 02-14-2012 10:42 AM
Gear Ratio vs speed cheddar Inboards 6 07-07-2009 02:10 PM
appropriate gear ratio gharai Propulsion 1 10-03-2008 09:05 AM
Gear Ratio? mossy Sterndrives 2 08-19-2007 04:31 PM
Help with ratio and prop selection, please. mperret Sterndrives 0 05-31-2006 01:12 PM
