#121
Rick W |
#122
| There were 4 questions there Rick. You've answered none of them
#123
Most customers come with a dream boat in mind. The very idea of the word "dream" indicates a disconnect between reality and optimum design no? With you little pedal design you are the customer and comfort is clearly not on your high priority list. |
#124
| To establish the design space I have found it instructive to start with looking at what the conditions are for the completely unconstrained case. This helps in understanding what each constraint is going to cost. In this case we do not know a lot about what the optimum solution is going to look like so I have set a relatively wide space for speed and displacement. The end result may be outside the range provided. It could be extended but most of what has been discussed so far is close to this. So displacement ranges from 0.5t to 2t and speed from 3m/s to 6m/s. The attached shows the power level required to drive the respective displacements at the various speeds. The design optimistation needs to start somewhere and establishing objectives for speed and target weight are good starting points. If someone cares to nominate values, the optimisation process can continue. I have found hull length to be the most demanding constraint so I can look at how that impacts on power next. Rick W |
#125
Clearly the "customer" who started this thread and a few others who have asked questions on it are reasonably well informed. My aim is to improve their understanding of how certain constraints or objectives impact on others not just offer accepted wisdom that others are apt to do. This is the process of optimisation - understanding the interplay of variables. This is the uncompromising approach to arrive at the best solution for the customer. I am very comfortable on my little pedal boat. There are not many other ways to get fit while laying on your back completely destressed. Rick W |
#126
My guess is that if the boat where built, the orginal poster would be more than willing to give up some mileage for some creature comforts. Not to mention the difference in resale values. That would be little consolation once he spent dearly on a boat that could not be resold easily. It's fun to sit here and waste bandwidth on your dream charades but the original poster, I think ,was actually serious. Myself I don't mind spartan accomodations and lack of real goodies but I don't want my drink to depart the table every time a boat passes me in the ICW. In my own designs, comfort and expectation trumps high tech and ultra green PC crapola nonsense and I sensed the same in the original poster. |
#127
#128
Rick W |
#129
Rick |
#130
#131
| Ah yes! In Pierre's world where comfort is everything you end up with a few thousand lbs down below .... and optimise wake production. but in the process make comfort sub-optimal due to noise, vibration and angry co-users of the ICW. Pierre, just add a couple of out-riggers. You can optimize stability! That'll keep your beer and apple pie from sliding off the table - don't accept compromise, you dont have to hold onto everything! Guys, I'm glad no-one has blown a cerebral fuse yet - seemed close at one point. Could we leave the semantics now? Yes, I'll try and leave my sins off the keyboard too. |
#132
#133
| Boy Brian do you read me wrong. |
#134
| Post #124 Quote:
And I see you've still not chosen to answer any of my last 4 questions. The only conclusion one could draw from that is that either you don't know the answer or realise that it will obviate the absurdity of your position. Even this statement "I have found hull length to be the most demanding constraint so I can look at how that impacts on power next", confirms that you must often compromise the ideal length in order to fulfill other conflicting requirements. I've never chosen to belittle the value of your opinion on the basis of your lack of appropriate qualification. But what I do take exception to is the notion that you know better than every single professional designer who accepts that compromise is an inescapable component of naval architecture (with the rather notable exception of your one anonymous NA, for whom compromise is unneccesary). That you are unable to distinguish between the terms opimisation and compromise suggests that your grasp of the variables at play is not just tenuous... it's completely non-existent.
#135
| Brian, I think you are missing the point of Pierre's posts. It would be a rare vessel indeed where there were not a set of design objectives, of which at least two were not in conflict with each other. The competent designer is one can find the best solution to satisfy the conflicting requirements. Invariably, that involves compromise. Comfort is a fine example - and I can assure you that the motion provided by many a multihull would score pretty poorly on that front.
| Coastal Cruiser | Guest625101138 | Boat Design | 246 | 03-06-2010 03:58 PM |
| 20ft coastal cruiser | Mupwi | Boat Design | 0 | 09-26-2008 05:51 AM |
| British Coastal Micro Cruiser | stumando | Boat Design | 22 | 04-17-2008 08:15 PM |
| Minimal Coastal Cruiser Revisited | Chris Ostlind | Boat Design | 5 | 10-27-2006 01:08 PM |
| The Ultimate Coastal Cruiser... | Sean Herron | Boat Design | 6 | 09-25-2005 10:18 AM |
