#271
| Rick - your prop size expose was news to me and I'm much obliged. Intuitively I felt that an outboard at low-cruise-type rpm was going to be inefficient, but I didn't realise how big the difference could be. And I'm past listening to an outboard at say 80% of max rpm where it will still be ok on fuel but not particularly efficient at the prop either. There probably isn't a big enough market for high thrust versions to warrant the neccessary drive shaft/gearbox mods required to get into the bigger props we'd like to see for 'our' cruisers. But this could change, and it mightn't be that hard. How about a 70HP powerhead on top of a 200HP outboard leg, and a cavitation plate twice the distance from the prop shaft? Also a gear reduction just below the powerhead. All to fit under that 200HP cowl... Pierre, would you mind posting costs of your 490mm CPP setup? I'm ready to say Ouch! But I might still want to find the budget rather than compromise. |
#272
The results are sometimes surprising - although the difference can be deduced easily, I had to work through the whole exercise before that realisation popped out. The outcome does not rule out the use of an outboard but it does show how it will impinge on possible solutions. There seems to be interest in more fuel efficient boats so the market pull may yet have manufacturers working on more fuel efficient options for outboards. Increasing the prop size is simple way to get big gains. Some of the very large motors have high thrust legs that are designed for survival under high thrust, low speed conditions. Maybe we will see this idea get into smaller outboards. At this stage you can get low pitched props for low speed applications but diameters are still small so efficiency ordinary. As you point out all the parts are there in other combinations but not available in a single package. Rick W |
#273
If homebuilding : 2a) Time available for building the boat. That the hidden budget part for homebuilders. 2b) Material preference/skills. Special building constaints. ie workshop size, special expensive tooling available or you have access to. |
#274
A yamaha T60 hi thrust outboard weigh 260 lbs, and cost around 6000€. A diesel volkwagen marine TDI4-75 cost 14500 € and weight 450 lbs. You need to add a ZF 45-1 1:3.74 gearbox, price 2500€ weight 132 lbs. and at least a prop 22" for 1000€. I omit details like shafting, exhaust, sound proofing. The diesel setup is at least more than 3 time the price of the outboard. The TDI4-75 is the best small efficient diesel (208gr/Kw). But you need to understand it comes at price of turbocharging, intercooling, and full electronic common rail direct injection. Maintenace price is on par. |
#275
Also the comparison is not one-for-one. The 55kW diesel matched to a suitable prop will be about twice the muscle of a 45kW outboard with its puny prop. As noted earlier the equivalent power for the diesel swinging a 600mm prop will be 30kW. Rick W |
#276
It is the only small diesel manufacturer that dares to publish figures, not a tiny curve where you cannot read something useful. |
#277
The variable pitch would give it plenty of reserve. The chart also highlight why a variable pitch prop merits serious consideration. Rick W |
#278
Expect 260 gr/KW at engine best torque, and over 500 gr/kw at lower settings. |
#279
#280
A volvo D2 40 29.1 kw engine cannot deliver better than 11 kw at the prop for 1 gph. and 28 kw for 2,5 gph. |
#281
| fcfc - so no real surprises. Outboard best for small boats. Diesel for larger cruisers. 'Our' (Sandy's) boat is close to cross-over point. So, short/infrequent day/weekend trips its obvious. If we seriously intend coastal cruising (=extended periods) and by the time we leave the jetty are sitting pretty low in the water (the comforts and supplies all add their bit to displacement) then the diesel is worth considering. But not obvious, agreed. And impact on draft could count against it (Oyster's 8" draft is what he desired and is impressive). I don't think I need to go that shallow, and I'm guessing but think a modified Topaz could accomodate the diesels additional weight plus the 'modern comforts' and not sink, although I know I wont get close to their loaded draft of 11". So its going to absorb the power of that VW (thanks for the link). Rather than a smaller diesel (you may be right, there may be no hgih efficiency ones that are smaller) specify a larger outboard for the comparison? |
#282
| I suspect that for boats under about 9m outboards will have an edge, and if I recall correctly thats the way you're going? As did Oyster. Over that and bearing in mind Oysters earlier comment about shallow draft, narrow beam 'Bolger type' boats ((eg Topaz) then the weight of the diesel might be a blessing and the cost penalty not that severe, all things considered. But I've made a mental note that stability needs to be assessed and worked on before I commit. eg minimize superstructure height and weight along lines I have posted earlier. |
#283
Put what you expect for your intended budget in your layout. Fancy a hull around it. Estimate costs. If budget less hull cost = negative amount : rethink layout and expectations or extend budget. Generally it is easier to rethink layout/expectations. If budget less hull/layout cost = small amount : put a outboard. If budget less hull/layout cost = big amount : put a diesel engine. |
#284
http://www.craftacraft.com/mark_van_abbema_v39 http://markvdesigns.tripod.com/siteb...0913bridge.jpg |
#285
The 18hp Sabb setup is nearly the same weight and pushes the boat better. The 4-107 had 2:1 reduction gears and a 350mm three blade prop. The Perkins burned 0.8gph to push the boat and the Sabb requires about 0.5 gph to push the boat or a decrease in fuel burn of about 40% right about where Rick predicts things with his large fixed pitch prop ideas. What does all this mean? Well it means a 40% increase in range from 450 NM to a range of 720 NM or enough range increase to turn the fuel gunky at the amount I use the boat now. I use the boat about 180 hours a year so my savings is about 54 gallons or about $150 USD here in the states. A whopping savings of some 4% of my yearly costs. Enough for a few nights in a marina. If we used the outboard situation and paid retail for an outboard or a CCP setup I think that if you put the difference in the costs into the market you would get more in interest on the initial cost differences than you would save in fuel. That is why these exercises are so silly but hey, one can dream. Maybe that is why there are so many outboards and virtually no CPP's in small boats. At least here in the states. |
| Coastal Cruiser | Guest625101138 | Boat Design | 246 | 03-06-2010 03:58 PM |
| 20ft coastal cruiser | Mupwi | Boat Design | 0 | 09-26-2008 05:51 AM |
| British Coastal Micro Cruiser | stumando | Boat Design | 22 | 04-17-2008 08:15 PM |
| Minimal Coastal Cruiser Revisited | Chris Ostlind | Boat Design | 5 | 10-27-2006 01:08 PM |
| The Ultimate Coastal Cruiser... | Sean Herron | Boat Design | 6 | 09-25-2005 10:18 AM |
