Old 09-23-2009, 03:23 PM
wardd wardd is offline
Rep: 443 Posts: 925
easy floater
The theory being there’s no physical law saying one man couldn’t build a nimitz class carrier single handed, given time and resources, its all in the details.
This concept is for a 30' class boat that could be driven to the ramp and launched in under 2 minutes.
With only the prime mover to park.
Agreed some performance might have to be sacrificed but what’s more important, speed on water or time on water?
First we do away with the trailer, build the boat to be its own trailer, with wheels that once in the water swing up above the water line and the tongue would pivot up along the stem.
This is just to get the idea rolling, I'll have more to add.
Old 09-23-2009, 03:36 PM
Squidly-Diddly Squidly-Diddly is offline
Rep: 187 Posts: 643
I'm with you, use the tires as fenders and drive the wheels
with a winch (just in case you want to have the boat haul itself up the ramp and a little ways on dry land without any PrimeMover).
Are you thinking motor or sail?
Old 09-23-2009, 03:40 PM
Rep: 443 Posts: 925
that could work
after i posted i had an idea, the bow spirit could pivot down to be the trailer tung.
im thinking sail as that presents the greater challenge, and what would work for that would work for power
Old 09-23-2009, 04:35 PM
narwhal narwhal is offline
Rep: 45 Posts: 68
Why not a prime mover with a tilting bed like the trucks that haul roll-off construction dumpsters, only lighter, perhaps on an extended 1 ton truck chassis? You've eliminated the trailer, and the boat doesn't have to carry its wheels and tongue along to hinder its performance.
Old 09-23-2009, 04:45 PM
Rep: 443 Posts: 925
if you could afford that you could afford to keep it at a marina
Old 09-23-2009, 04:47 PM
Rep: 443 Posts: 925
roll on's are expensive
this is for the average weekend sailor with limited time
Old 09-23-2009, 04:55 PM
Rep: 45 Posts: 68
But there are a number of lakes and waterways with no available marina space, or no marinas at all, yet having ramp access. These waterways are often the most scenic and least crowded, and therefore desireable for cruising.
Old 09-23-2009, 04:57 PM
Rep: 187 Posts: 643
narwhal, I don't think the angle would work, too steep
coming off the trunk, even if you backed the truck into the water as much as possible.
Plus, you still need to lower the bow with a cable, just like a debris-box.
Lumber trucks will do actual "drops". They just let the whole load drop after the tail end is sitting on the ground.
Also, I think the general idea is to avoid any dedicated new vehicles.
I can't imagine using a general purpose dump-truck to launch a boat, especially a 30 footer.
Do about 30mph in reverse, then hit the brakes hard, stopping just short of the end of a deep water dock?
Old 09-23-2009, 05:01 PM
Rep: 45 Posts: 68
All good points.
Old 09-23-2009, 05:10 PM
Rep: 443 Posts: 925
to add these features to a boat i dont think would add much to the structure, just at certain stress points
the difference between a fully aerobatic airplane and a normal small plane is not that much it would be the same for this boat after if it can travel on a trailer it could travel on its own wheels just a matter of design details
Old 09-23-2009, 06:04 PM
Rep: 443 Posts: 925
another idea i had was to make the extendable keel with a square tube with aluminum ribs that slide up and down it with cloth of some king forming the shape, sort of like a cloth covered airplane wing when extended
when the spar is retracted the ribs slide and the cloth folds, there could be a recess in the hull in which it folds
the fixed tube for this could also serve as the mast step saving room below
Old 09-23-2009, 07:43 PM
Rep: 2891 Posts: 8,795
Why would you want to burden a design with this level of limited necessity. All boats are a difficult set of compromises. Add increased complexity and convolution to yet another set of concessions, toss in some extra weight and lack luster performance as a result and you have the precise definition of a water pig. Possibly a very cleverly engineered pig, but a pig none the less, with an extremely limited market to boot.
Old 09-23-2009, 08:05 PM
tom28571 tom28571 is online now
Rep: 1424 Posts: 1,649
It's not what you don't know that creates most problems.
Its what you know that ain't so.
These have been built for a long time and none have been more than curiosities. But, have at it and maybe you will provide the breakthrough. That is, a boat that will meet all restrictions for the highway as well as a car that will be a good and safe boat. All so far have been barely adequate road vehicles and very poor boats. Some fortunes have been expended. Of course, that can be said of many boat builders and dreamers.
Tom Lathrop
Old 09-23-2009, 08:18 PM
AnalogKid AnalogKid is offline
Rep: 10 Posts: 26
Easy Floater
Why even have to park the prime mover?
I've seen this boat come to our local beach. They park up the ute and trailer inthe car park then drive the boat off the trailer, down the ramp and off the beach into the sea.
Old 09-23-2009, 08:52 PM
Rep: 443 Posts: 925
The underlying boat can still be designed to compete with other boats with what im talking about removed
I spent most of my working life designing and making tooling and my philosophy was and still is make it simple make it adaptable and most often it had to able to be converted in short order for different parts and back
thats the idea im bringing to this concept start with a simple boat but design into it the ability to accept assorted attachments ie wheels and a way to attach it to a prime mover
all of what im talking about here can be lifted out of the way for a day of sailing or removed for extended stays in the water and your back to a basic boat
the dimensions would be about 30 feet long by 8 feet wide and under 13 feet tall, highway ready
I now design and build my own farm implements and my first approach is to find what I’ve already made and see if I can adapt it to do the new job without changing it in a way that it cant still do the original job and I’ve come up with some rather good stuff
thats my concept here start with a boat design that does what a boat is designed to do then see what modifications are needed to perform the new function without changing the way its able to perform the original function
in a way its more complex of course, but the complexity can be removed back to its simpler form
the compromises would come in its secondary modes not its primary modes in that maybe you’ll only be able to pull it at 40 mph and not 65.
As for the keel is it more complex, yes, am I sure its practical no, but it’s a complexity of very simple parts and I have seen the concept used successfully in other circumstances
Easy Thermoform archeryrob Materials 2 07-30-2009 11:33 AM
Easy 37, any thoughts? ThisnThat Multihulls 3 11-14-2008 07:05 PM
That was Easy....Not! flydog Boat Design 4 03-03-2007 08:58 AM
How easy is it to intern? nomadic_texan Education 6 08-28-2006 10:18 PM
Easy Job Tim_Hastie Services & Employment 0 06-14-2004 09:27 AM
