  #31
Old 07-24-2010, 04:59 PM
brian eiland's Avatar
Rep: 1577 Posts: 2,737
Originally Posted by apex1 View Post
...but you are aware that they are not cheap? And that the shipping from EU to Pacific Northwest is above 100 thousand $$$ for a vessel that size.?
Regards
Richard
I could well imagine an expensive trip to ship to the NW.
But with all the steel boatbuilding that goes on up there I would imagine you could find someone to do a bang up job for a reasonable price. Then maybe find someone else to fit it out.
I particularly like the looks of that classic 'sailing design', even though I understand it didn't sail particularly 'fashionable'
I have another absolute beauty I what to post but my scanner is on the friz
  #32
Old 07-24-2010, 05:11 PM
Originally Posted by RCardozo View Post
.... My vessel is larger and less authentic but built at about the same time. I am still in Baltimore. The boat is repainted beige and white with a black and red trim. She travels around usually north of the bay bridge.
I believe this posting by RCardozo on another barge subject thread bears repeating here:
The real truth about a Dutch barge
I have been reading these posts and there is a lot of confusion about these vessels. I own the "Morgenster" ("Morning Star" in Dutch). She is a Dutch 73' sailing barge built in 1893 in Leiderdorp Holland. She is constructe of hammered iron plates rivetted together. This is similar to mild steel. These vessels were built to haul smaller cargo loads in canals rivers and coastal areas. I am in Baltimore on The Chesepeake bay. The bay is a shallow estuary similar to the former inland seas of Holland. My vessel was built before the combustion engine took over so it is sail powered. The mast is on a hinge so it can be lowered to go under bridges and sell produce in town via the canal system. Being a cargo vessel the design is to maximize blockage for cargo. Lots of space, easy in and easy out. The flat bottom reduced draft and allowed the boats to beach at low tide load cargo and then float off at high tide. My draft is 3'. The leeboards on the sides were used to avoid the maintenance and inconvenience of a center well and they also utilize an airfoil curve to assist in windward performance. When power came on the scene the hull shape changed with more pointed bows and no leeboards. Since these boats were carrying cargo they were very heavily loaded. The big rounded bow and stern added buoyancy to keep from being over taken by seas. The weather a barge can handle has a lot to do with the load. Since use as a yacht is very lightly loaded a Dutch barge can handle some rough seas. I have had mine out in the bay in 65 mph winds and 12-15 seas and she did fine since we were running with the wind. Now bear in mind with a flat bottom and 17' beam the last thing you will do is want to go broadside to the seas. That is the vulnerability because it will roll and scare you to death or beat you to death or capsize. I can't see blie water use of a dutch barge but it can do coastal use in rough weather if you behave. In summary these boats are very safe if handled correctly. Once motoring acros the Neuse river in NC. there was a 6' sea coming from the aft quarter. The speed of the seas and the speed of the barge were just so that the boat set up a harmonic and a gentle roll that slowly increased to 45 degrees! Slowing down stopped it. If I was bow or stern to the wind no problem. Even with strong seas off the bow quarter she justs pounds through. I would not hesitate to take the boat across the English Channel and many have. Trade between France and Holland and England had these vessels going to and fro all the time. Now the captains were not stupid. I doubt they went out with only 12" of freeeboard which was not unusual in a canal. Anyway that is enough for now. Greenseas knows what he is saying. Seaspark is a tad pessimistic.
I love my barge. (A man and his barge is a beautiful thing).
  #33
Old 09-27-2011, 03:12 PM
emc2mm emc2mm is offline
First, Pick a solution and have an adventure building or creating it. Any one have any plans/drawings or shape files for a dutch barge hull? or a late 1800's river scow with the sail like they used on the delta's and rivers on the west coast? They would sail to the ports full and turn around and sail back upstream.
  #34
Old 09-27-2011, 03:34 PM
RCardozo RCardozo is offline
RCardozo
Rep: 21 Posts: 51
I saw a scow in San Francisco martitime museum and thought it was built to do the exact same thing as a european sailing barge. Built out of wood but same use and general form.
  #35
Old 09-27-2011, 07:57 PM
Wavewacker Wavewacker is offline
Rep: 136 Posts: 421
Be cheaper to build that 60' river boat by Phil Bolger, it can be dressed anyway you like it.
As to housing and building a boat (or buying one). Regardless of what the real estate market might be like now, years from now you'll seel the RE for more (if you can stay away from toxic dump sites). A Boat, any boat, unless it's a collectors item, is personal property and it depreciates just like a car or mobile home *depending on what it is) and one off boats built by owners will usually drop in price faster than your anchor.
So, as was said above, living in or on something is not free, better luck buy RE living there and selling it later on, it's always worked better than living in personal property.
But, I'd like to live on a boat for awhile too!
  #36
Old 09-27-2011, 11:12 PM
luckyjr luckyjr is offline
Rep: 10 Posts: 11
thinking out of the box is what made this country. the problem now is, they gave away the box. I am about 60% finished building my 29 foot weekender. I used steel studs for the walls and floors and it turned out great and weighs less than marine plywood. If you want to build your own, I could give you some pointers. I owned a couple of steel plants in my working life. Love ur city, good luck
  #37
Old 09-28-2011, 06:09 AM
Rep: 136 Posts: 421
Luckyjr, Sounds like a good idea, just a few questions:
How did you bend those studs to fair the hull and form the bow?
How do you get them to butt up to be water tight, is it skin on frame?
On the interior what did you use for the walls to the frames and what does it weigh?
HEY, SKIPPER G, GLAD TO SEE YA HEAR!
  #38
Old 09-28-2011, 06:12 AM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
I saw a canal boat in the states the other day and thought of this thread. Somebody has imported one. Pics to follow later.
"You can't solve all of life's problems with epoxy" - My Wife
  #39
Old 09-30-2011, 08:51 PM
Look thru this extensive discussion and you will find pre-cut kits as well as plans:
Dutch Barge long distance cruisers
  #40
Old 10-01-2011, 12:48 AM
Rep: 10 Posts: 11
6" WIDE WEIGHS 1.49LBS/FT AND $1.00 A POUND. Comes 60' long
If i were building, All light gauge galvanized steel. Pontoons and Structural
Mini 12 or scale down America cup bilco Wooden Boat Building and Restoration 26 03-23-2008 04:18 PM
Installing LPG in boats in America. tom kane Open Discussion: All Things Boats & Boating 50 07-23-2007 10:42 PM
10 meter aluminiun mast with ring on ebay from 1 euro filiperosa Marketplace 0 07-01-2006 03:09 AM
Shipping and Marine / Offshore Vacancies in North America Mark Charman Services & Employment 0 05-18-2005 09:08 AM
euro 23/how many have been built ????? hockeypuk Metal Boat Building 1 04-27-2004 12:15 AM
