#31
| Uses Within the scope of this thread, we are discussing the utility of the Dutch barge design as being a roomy, low powered and economical live aboard for cruisinmg mostly inland waterways, rivers and canals of the US. Your expertise in the design of a small (40 to 50 foot) cruising version would be quite valuable to the discussion. Choice of building materials is also important to bring the viability of having a Dutch "style" barge to those of medium income. As in Europe, there are many who live year around on converted and replica barges and are quite happy with their environment. Here, we're seeking to bring the same lifestyle and vessels to the US waterways. |
#32
| Coaster We call these kind of ships coasters, yes we borrowed it from the Enlisch language. Included pictures of a typical old and a modern dutch coaster. |
#33
| Economical cruiser. Greenseas i completely agree with you, there is a need for the kind of vessel you are interested in, also in Holland. When i have time for it i will make a design proposal in multi chine construction. It would be helpfull if you could find some pictures of the kind of features you like on a boat like this. |
#34
| Thank you. I will try to come up with a concise narrative for a motor barge within the next few days, and I do appreciate your help. |
#35
| Maybe a bit late Seaspark, Replying to a previous remark you made about the Northsea, I wouldn't do it anyway ;-) 6bf on the Waddensea isn't comfortable but doable, even with an relative low powered (kromhout diesel) barge. Biggest problem is the rolling and maybe even more, on high seas the windows will be blown out. (at least on the typical old style barges, the steering house is sertanly not made seaworthy)
__________________ |
#36
| Common Sense navigation As with any other vessel, you have to know what the reasonable limits of the vessel are and the seas that she will be safe in. Granted, many of the pilothouses are fold down and have large window areas that are vulnerable, but in knowing that, you operate in more moderate sea conditions. With any boat design we can introduce extreme sea conditons where the integrity of design will be jeopardized. In the US, even inlets on the east and west coast can have impassable sea conditions, but most knowledgable skippers wait until conditions improve before crossing them. |
#37
| Multi chine motoryacht Greenseas you are even more stubborn then i am. Made a post in the Troller/Trawler thread about what i think you are looking for. http://www.boatdesign.net/forums/sho...4&postcount=51 |
#38
__________________ Guillermo Gefaell Ubi dubium ibi libertas Motorsailers & Motorsailing Banjer 37 Motorsailer Club |
#39
| Have a look at www.bransonboats.com we design steel dutch barges that are available as precut kits or DXF files for cutting locally. Also doing passagemaker type boats as well. Although some of our barges can be rated as cat B of the RCD my thoughts are that there are better shaped hulls that are more seakindly than a Dutch Barge. |
#40
| Dutch Barge Steel Kits Have a look at www.bransonboats.com we design steel dutch barges that are available as precut kits or DXF files for cutting locally. Also doing passagemaker type boats as well. Although some of our barges can be rated as cat B of the RCD my thoughts are that there are better shaped hulls that are more seakindly than a Dutch Barge. Nick |
#41
| Thank you Thanks for the information. I have seen branson boats, but wasn't ware that they offered files for local steel cutting. |
#42
| Steel kit cutting files Yes, we have supplied DXF cutting files as far away as Australia! At lot easier than arranging shipping and road transport. Getting back to the question of Dutch Barge seaworthiness we have designed two Passagemaker type vessels with a low enough airdraft for the French inland waterways. Loads of accomodation yet very seaworthy. By the way our website address has been changed to www.dutch-barges.net ![]() |
#43
| Jeez where to begin. I own a Dutch Sailing Barge built in 1893. Barges were originally designed as inland cargo vessels. Their shape is due to a number of factors. A flat bottom could be beached loaded and floated. Lee boards left a large interior space for maximum blockage of cargo. The blunt rounded stern and bow gave boyancy to plow thru heavier seas. They punch through the waves less than cleave them. Kind of a wet process. Still they were inland boats for the most part. Some are of heavier construction for heavier seas. Originally sail powered the mast could be lowered to get under bridges and sell your cargo in town. When combustion engines came on the scene they were added. \you do not want to be on a flat bottomed boat in a following sea off the aft quarter of any size. It will roll. The new replicas are really selling the size and modifying the motorized versions that developed after combustion engines were developed. This means sharper bows, more v hulls etc. |
#44
| Hi, Cardozo! Could you post pictures of your barge? Cheers.
#45
| Flat bottom barges The intial intent of the thread was to get input on an economic design of a Dutch style barge that could be built reasonably with any number of materials. The flat bottom barge will naturally roll in a seasway, but is probably the best for an relatively amateur builder. Any number of building mediums can be used from steel to strip plank to ferrocement. The end goal is to build a long distance capable Dutch style barge for predominently inland liveaboard travel. Few other designs have the internal volume that would provide exceptional living space, tankage and all of the other variables within a single hull form. A 5 to 6 knot speed would be acceptable in most cases as people who live on barges are generally not in a hurry to get anywhere. The words "Ocean capable" and " Barge" are seldom used together even though a modicum of seaworthiness is desired. |
| REALLY small cruisers... | Sean Herron | Boat Design | 23 | 09-28-2006 11:59 AM |
| Dutch Sailboat With Leeboards | DRC | Boat Design | 9 | 12-19-2005 03:48 PM |
| Human powered propulsion - heavy duty & long distance | icetreader | Boat Design | 8 | 10-28-2005 08:26 AM |
| Buy power cruisers projects (18-24 ft.) | Splice | Marketplace | 2 | 09-12-2005 02:30 PM |
| *Help* We call for more info. about our Dutch Steel Yacht | Ekelunden | Sailboats | 4 | 02-01-2005 04:37 PM |
