Old 08-14-2011, 12:32 PM
Jason Elliott Jason Elliott is offline
Rep: 10 Posts: 5
Dutch barge for lake Ontario
My family and I have decided to take the plunge, Presently we live offgrid in a pair of yurts Canada. So we are used to limited space, power , and cold winters. We are considering a dutch barge style, 12 beam by 48 foot. Words of advice..or suggestions would be appreciated. BTW I am willing to build, but it would be great to get a project boat at reasonable price.
Old 08-14-2011, 06:47 PM
Brian@BNE Brian@BNE is offline
Rep: 140 Posts: 222
Here is a pretty good site for info. http://www.barges.org/main.php?section=1707&SectionID=4
There are links here to a number of designers and builders. You can probably find someone that can supply you with CNC CAD files to at least have a local Canadian supplier cut the steel for you. You really want to get a yard to weld, sandblast and prime for you. Even better if you could get a Canadian supplier to build to 'sailaway' stage. There's plenty of time and money required just for the fitout stage, you really don't want to get bogged down with the hull build.
I think it would make a great off-grid solution. Why not go for 60'? Have a space on deck where you can drive a micro car on/off with some ramps.
Old 08-14-2011, 06:54 PM
Rep: 10 Posts: 5
Hi Brian, thanks for the response, I would love to have a 60, but the marinas around here seem to have space for 48 but not larger, I have been calling around to find out rates. As for the buildup. I would love to find someone to do the initial stage up but money says I will be welding it all myself. I do weld for a living, and I do have a good supply of steel available to me.
Old 08-14-2011, 09:29 PM
Rep: 140 Posts: 222
Jason, I'm sure that with a well thought out layout you will be quite comfortable in 48'. Extra length allows a bit more privacy/luxury but your reasons for staying with 48' make sense.
Good luck with the project, hope you will have some help along the way so it doesn't take too many years. Its a pretty big project!
Old 08-15-2011, 01:13 AM
brian eiland's Avatar
Rep: 1577 Posts: 2,737
Have a look thru this subject thread as well...lots of info:
Dutch Barge long distance cruisers
Old 08-15-2011, 10:27 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
Why a Dutch barge in Ontario?
There are other solutions.....
Old 08-15-2011, 11:11 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Or my own submission.....flat-bottomed steel construction, full width house, folding unstayed spars, twin outboard power, twin centerboards.....
Old 08-15-2011, 11:56 AM
sharpii2 sharpii2 is offline
Rep: 471 Posts: 954
Attachment 59956
A very interesting design.
I just don't get what the blunt ends are for. I suppose with the Thames barges, it was to get more internal volume, for light, bulky cargo, such as hay, and, possibly get greater displacement volume. But I suspect it was more the former than the latter.
I can imagine bending that sheets of steel around the sharp turn of the bow would be no job for an amateur. I have worked with 0.125 inch plant in the stamping industry. It is no joke. It is heavy, has sharp edges, and has a vicious spring back to it.
It appears you have finer, pointed waterlines under the bow. I don't know if a Thames barge had those. I think its bottom swept up like that of a scow, above the waterline.
It seems like the bluff, round bow on this design is mostly an affectation and a costly one at that. Imagine butting through a head sea with that.
I am highly suspicious of the terms 'perfect' and 'best'. I favor the terms 'inadequate', 'adequate', and 'better', instead, with the first of these closest to being an absolute.
Old 08-15-2011, 02:14 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
sharp...
As Jason does not mention going anywhere internal volume (or living space as he does mention the vessel being home to some number of people) would be a design driver. As he dictated dimensions the designer is inclined to pull the midsection out to maximize that volume. Thus short ends.
And I've bent 3/16" plate into a boat shape and believe it's entirely possible. Come-alongs, hydraulic jacks, front end loader, whatever it takes.
Typical Thames Barges only have a chine and flat bottom amidships, their ends are very shapely with deep rounded sections in the bow and rounded sections turning concave aft.....very graceful hulls but rather complex for a sheet material build.
I guess you could say all design is affectation...........the style of your going is what it's all about.....
This is the general shape of the design above....
Old 08-15-2011, 04:45 PM
Stumble Stumble is offline
Rep: 599 Posts: 1,086
Jason,
It seems I am always the naysayer around here, but I would highly advise against building. It won't save you any money, and the time involved in the building process would be better spent doing other things unless you have a burning desire to build for the sake of building.
I would advise instead to get on http://www.boattrader.com/ and do a search for houseboats in your area. Just a quick perusal pulled up a number of boats in the 45-48 foot range in reasonable shape for around 50,000. It may seem like a good bit, but a new build this size will be multiples of this amount, and it wouldn't be impossible to spend 50k just on the engines.
A decent houseboat does have limitations, like limited seaworthiness, and they absolutely should not be taken off shore, but for a live aboard, river, and lake cruising they are great. And a houseboat is almost exactly what you are looking for, lots of interior volume for living accommodations, and that's about it.
Old 08-15-2011, 07:16 PM
You might be in for some real surprises when you start looking at used steel houseboats built in USA. I looked thru a few...and what shoddy condition after only a few years....they are rust traps waiting to happen.
Old 08-15-2011, 07:21 PM
Didn't know what a "yurt" was??
http://www.shelter-systems.com/solor-dome.html
http://en.wikipedia.org/wiki/Yurt
Old 08-15-2011, 07:31 PM
Lister Lister is offline
Moxy
Rep: 45 Posts: 172
Attachment 59956
Tad I like your project very much. It can be a real winner. I hope someone will jump on it.
I know everyone will kill me, but I really don't care for the Bolger.
You have a sense of aesthetic Bolger laked completely.
Nobody can beat "Le Corbusier", even if Bolger tried hard.
Lister
"I always like walking in the rain," he said, "so no one can see me crying."
Charlie Chaplin
Old 08-15-2011, 08:07 PM
Brian,
The original question wasn't restricted to steel boats, that wasn't brought up until later. However if the question is restricted to just steel boats then perhaps you are right there aren't any available, but then I never looked for steel hulls.
That being said I can't see why in this application a steel hull would be preferred over fiberglass. So long as he buys a boat as opposed to building one.
Old 08-16-2011, 10:00 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
This is the fascinating thing about boats.....there are so many different approaches to the same issues.....The reality of what is available used in North America when you say "houseboat" is pretty awful....plastic ticky-tacky boxes poorly built and filled with fake luxury crap and foolish propulsion systems that none can afford to maintain or use.......I guess some are happy with this...but I suspect only for the 2 week summer holiday....I can't imagine actually living in such a thing.....
For full time living one wants something that can be home....a substantial vessel with some class and the ability to carry any style interior from classic mahogany "gentleman's club" to modern loft apartment, or knotty pine country house.......
Something like this.......still needs skylights, rigging, toerails, etc.....
Dutch Barge long distance cruisers Greenseas2 Boat Design 320 07-29-2011 09:30 AM
New design 12m Dutch Barge micspoko Boat Design 1 05-26-2011 09:24 AM
Dutch barge model leggers Boat Design 24 05-08-2011 02:28 PM
The new project I am working - Dutch Barge 12m micspoko Boat Design 5 05-04-2011 04:20 PM
lake barge texasboatbuild Boatbuilding 5 08-09-2005 09:33 PM
