| Drawing Translation I am working with a shafting plan out of the Netherlands and on the shaft tapers they have the call out "conus 1:10" or "conus 1:12". Is this the same as a taper, or is it applied as a taper were over 10mm there would be 1mm of taper, 2mm overall on the shaft, or does it mean more like a truncated cone where there will be only 1mm difference overall on the shaft? I don't trust the scaling as I am working with a scan of the original drawing. Don't have access to the actual shaft ends at this point. Thank you for your assistance in advance. Regards,
__________________ Regards, Peter |
| I would try contact the designer if it is an "modern" design and an existing design office. Otherwise it should not be difficult to check the orriginal drawing. By the way: Working from a scanned drawing and building a boat without paying the designer would NOT be the way to go. This should NOT be endorsed! I do not think this forum should help with this kind of illigal practices. I think a designer should get proprly paid for the desings he or she has spend a lot of time and efford making. |
The original drawings are stored up some place... Easier to post a message than go rummaging.. Cheers.
| Go5Go, I think what you have there is correctly called a "pitch" in English. The 1:10 would taper 1mm in every 10mm, in section. In other words, that would apply to the surface, not the diameter. Better to use the original designer's opinion, however.... Steve |
| Drawing of a 40' flat rack? | Seattle lite | Software | 0 | 09-16-2005 11:27 AM |
| Raster to Vector Services / Conversion of paper drawing to CAD format | brtodi | Boat Design | 0 | 04-20-2005 12:05 PM |
| Design & Drawing Service | pbhat11 | Services & Employment | 0 | 09-17-2004 05:09 AM |
| need drawing of rowing boat | arch3d | Boat Design | 11 | 04-20-2004 05:43 AM |
| Design and Drawing of First Boat | dishsail | Boat Design | 14 | 07-30-2003 04:53 PM |
