  #31
Old 05-26-2008, 05:15 PM
sailing canoe sailing canoe is offline
Rep: 33 Posts: 89
Hi Clinton; I think from the fast row boat thread you have got this boat planked . So how did it work? Or is this another boat? I posted you on the fast rowboat thread about what material you used for spline material at 1/4 scale. I ripped a 3/16 rip of lexan but it would not make the curve for the stations. I've started fairing my pear shaped curves so maybe this will be a moot point but.... Thanks any way - Nick
  #32
Old 05-26-2008, 05:18 PM
Rep: 33 Posts: 89
Humm I looked futher up and see you are talking about 7 planks per side . Definatly nor your Faairing. Has it hit the water yet?
  #33
Old 05-26-2008, 07:00 PM
Clinton B Chase Clinton B Chase is offline
Rep: 18 Posts: 127
This post regards the design of my "Maine Coast Dinghy", a 18'8" sailboat for the family and a raid if necessary, though it is becoming more and more a family sailboat!
Yes it'll prob. be 6 or 7 strakes, prob. six maybe even 5...I will line it off on a 1/4 scale lofting which I have yet to start. Probably will do this work later in summer after I get the faering done with a tleast one pair of oars...due to launch for August 1.
I am contemplating doing a 3 panel stitch-and-glue hull for the boat too, but I am betting that I'll be leaning back to glued lap after seeing some sketches.
I'll keep people posted on this technique...as far as I know it hasn't been done quite this way...it is a synthesis of ideas from a number of sources...hardly "my" idea...."standing on the shoulders of giants..." s always.
Cheers,
Clint
convert hull-drawing to dxf jonnyb Software 5 11-15-2007 10:59 AM
Converting a Carval Plank Hull to Glued Lapstrake Ply Stephen Hopkins Wooden Boat Building and Restoration 1 01-19-2007 01:59 AM
Glued Lapstrake Jim Herbert Fiberglass and Composite Boat Building 0 08-30-2006 08:17 PM
Glassing Lapstrake jeff goldberg Boat Design 4 08-11-2005 12:47 PM
3D hull model to 2D drawing cut patterns Software 10 01-30-2002 07:43 PM
