| Drag question........ All right, first post and first question. Cut Me a little slack here as I used all My boating knowledge to answer the no spam question on the sign up page. I have been looking at motor sailer's recently. They all have a prop hanging off the bottom of them. Since the motor is generally used just for maneuvering around the harbor, Wouldn't it present a large amount of drag while under sail? Do they have feathering props? Wouldn't a pump set-up like a jet boat result in a lot sleeker underside? Am I on crack and over thinking this? I lied, multiple questions................ |
| A sizable prop does have a large amount of drag. It is best to have the prop shaft locked while sailing. A lot of motorsailor owners just accept the drag penalty as they are not racing. Others do opt for feathering or variable pitch props. I suppose there may be a few water jets on motorsailors somewhere, but I am not aware of them. A conventional shaft and prop are cheaper and very reliable so that is probably the reason for not resorting to more efficient alternatives. |
| The next question ("more efficient alternatives") is more efficient "when". It is a "motor-sailor", you say, which indicates it is motoring probably more than it is sailing, or, at least, a lot. A feathering prop isn't bad. Jets open up a can of worms you're gonna want to put back. Too big for an outboard? |
| You don't say what size vessel you are looking at. Prop drag is in proportion to the prop diameter and a 70 - 40 (70% on the motoring side) will generally want a larger fixed prop turning slowly. A 40-70 will be more likely to have a smaller prop and then a feathering prop is affordable and will give you better performance under sail for light and medium air often adding a half to one knot to the speed under sail. It's all compromises and no absolute hard and fast rules.
| How so? While I have never owned a jet powered craft, I have worked on quite a few pumps being a machinist. Most of the problems I see with them a maintenance (or lack thereof) related along with the throw away PWC manufacturing standards. Don't know yet. How big is too big for an outboard? |
| Delftship Design Question on Design Drag vs Hull Ratio | Fanie | Boat Design | 10 | 06-08-2009 06:43 AM |
| Foil Drag | Panos_na | Boat Design | 4 | 03-20-2008 01:11 PM |
| hull drag | marke1952 | Powerboats | 0 | 09-17-2006 08:28 PM |
| Small Boat Drag Question....help! | Biomechanist | Boat Design | 2 | 10-31-2004 08:36 AM |
| Question on Drag | foxxaero | Boat Design | 22 | 12-23-2003 03:46 PM |
