Old 12-28-2007, 05:36 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Double keel or single keel ?
If one uses two small keels a distance apart, would they have the same effect / functionality as one with double the area ?
Regards
Fanie
Water ! Just gimme water !
Old 12-28-2007, 10:08 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
They theoretically would be the same. But it seems to me that one larger one would be more efficient and have less wetted area, and only one tip loss, less complex too (fewer parts to build). One fewer keel to raise when in the shallows.
However, on a cat having two small ones has the advantage of always having one in the water in chop or when flying a hull. There is also some advantage to redundancy in case of failure, two smaller ones would have less draft too.
I have thought this back and forth on a cat I want to design and build, but I have not reached any conclusions. It seems there are benefits to both, so take your pick.
Old 12-29-2007, 12:35 AM
PAR PAR is online now
Rep: 3125 Posts: 9,398
Tandem appendages have been tried, but you have more drag, even if the combined total area is the same, the additional leading, trailing edges and vortices mostly counteract any advantage.
Tandem dagger or centerboards has a lot to offer, especially in helm balance and a fair number of yachts have been fitted this way.
Old 12-29-2007, 12:41 AM
masalai masalai is online now
masalai
Rep: 1689 Posts: 7,507
Fanie, On your new toy, Go fast & you will never experience any lee worries - having too much fun. Fly both windward & centre hull for more drive (lift) and don't worry too much about that (pointing higher) yet.
Old 12-29-2007, 04:16 PM
Fanie's Avatar
Fanie
I apologize, I should have mentioned this is for the centre hull of a trimaran. One consideration to using two shallow fixed keels would be so the centre hull could stand upright by itself. Another would be shallow draft.
Thanks Masalai, but I doubt the cat is going to be fast, maybe if I redo the ally mast with GPR and make it longer and fly a larger sail. At the moment I'm just trying to figure out what is functional and what not.
Regards
Fanie
Old 12-29-2007, 04:39 PM
masalai
My cheeky answer still applies, remember KISS. In that vein, single dagger-board is more than adequate & easier to control. The leading edge of the case can be part of the mast step.
If you must then extend the case & make it swing up, held forward by a rope and your magic cleat. (I suggest against the cleat - rather be aware of the depth than unexpected broach as the keel swings up)
Old 12-30-2007, 02:54 AM
Previous Member
Rep: 0 Posts: 0
If you have a single board that is 2ft deep and 1ft long replaced by two 1ft square boards then the drag on the boards to achieve the same lift is the single board is close to twice as much. This is based on a NACA2412 foil. Will be similar for others.
The reason for the dramatically reduced performance is the change in aspect ratio. This increases the induced drag for the low aspect foils.
If you keep the same aspect ratio then the loss in performance is not so great. You are changing the Re# so the impact will be less significant as the speed goes up.
Rick W.
Old 01-21-2008, 06:47 PM
Member
Rep: -33 Posts: 951
Yes. if they were canted out 25 degrees making the leeward one upright when heeled 25 degrees, increasing it's lateral resistance 100% from that of an equal sized one heeled 25 degrees.
Brent
Old 01-24-2008, 10:33 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
Brent
To complicate that effect, the windward side dagger now totally loses resistance because it is 50. to the vertical, so the net gain is negated, but maybe its better to have one board doing all the work under water instead of up in the turbulent windward side?
Maybe the 25. angle is a bit too big for a MacGregor style craft that have to be sailed like a Laser, (not recomended beyond 10). heel.
Also, the bigger angles make inroads into the accomodation area.
My next boat is planned to have dual daggers, so I am interested in the logic here. I have specified them to be vertical.
I am also interested in the "toe-in" geometry calculations and how performance is affected.
Old 01-25-2008, 01:38 AM
Fanie's Avatar
Fanie
How about more than one dagger board per hull - one more foreward than the other... you use one at a time only and could use one in one hull at a time. High speed sailing you use the foreward dagger board to improve the rudder leverage, switch to the aft daggerboard to tack faster and decrease the turning circle diameter.
Regards
Fanie
Old 01-25-2008, 01:46 AM
Fanie's Avatar
Fanie
In my mind toe-in (if any) should be very small. Half a degree. The toe-in angle will increase with speed without adjusting the angle and only appy if more than one dagger board is used. Streight daggerboards should have a sideways bobbing action side to side, but only if the hulls are as streight as well. The slightest deviation from 100% everything in line should veer slightly to one side which is corrected with the rudder without knowing. Assuming still water and no wind.
Regards
Fanie
Old 01-25-2008, 07:23 PM
Member
Rep: -33 Posts: 951
Want toe in? Sheet her closer and point higher. Same effect.
Brent
Old 01-25-2008, 08:23 PM
rwatson's Avatar
Its not that I would want toe-in just to say "Look Ma - I have toe in!"
Boats on a beat dont sail straight - they crab across the desired direction of travel.
Many modern day racers have variable attack angles for their boards to customise gain v speed for their boats
I have been told that there are optimal angles for dual keeled boats.
These angles usually result in a "toe in" angle to increase lift on a beat, but without creating too much drag under other conditions.
I have yet to read any theory on this - but someone may know a source.
Old 01-26-2008, 10:57 AM
Fin mounted trim tabs . . .
Old 01-30-2008, 06:45 PM
Member
Rep: -33 Posts: 951
The toe in theory was developed by tank tests , which propel a boat from a fixed point rather than by sails. The relevant angle is the angle between the keel and the sails, something that propeling a model in a tank from a fixed point doesn't relate to.
Brent
18' Canting Keel Single/Doublehander Doug Lord Sailboats 11 06-29-2007 09:19 AM
twin keel 2' draft instead of single 7' draft on 65' yhxaig Projects & Proposals 3 11-12-2006 05:25 PM
twin single keel Garth Boat Design 5 08-18-2006 05:21 PM
Replacing an iron keel with a lead keel. Kris-Stockholm Boatbuilding 4 06-21-2004 12:45 PM
4m single handed keel boat Guest Boat Design 20 02-04-2004 08:44 PM
