Old 01-20-2007, 07:46 AM
BTScow BTScow is offline
Rep: 10 Posts: 42
Does anyone recongize this boat?
I have read the threads pertaining to taking the lines of boats - thoughts ranging from outright larceny and disgust to mild disapproval and the exceptions that fall in-between. I hope, "historical preservation" is one such exception that will mute the land-slide of reprimanding and figure pointing responses.
This is a boat that is being restored by Brightwork Boat Works in Madison, WI. It was dragged from a shed and no-one seems to have any idea of the designer or builder. I am a N.A. in study and thought it would be a good real life example to study for stability curves and hydrostatics - besides being good looking the information would be useful to the new owner - capacities and all.
Circ. 1923 -
21' LOA
6'7''Beam
Power: Kermath "make or break"
Draft - 24''
I am happy to chase down the smallest of leads. And yes, I know I drew the boat backwards.
BTScow
Old 01-20-2007, 11:24 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
William J Deed drew lines similar to this. He was at International Shipbuilding Corp at Nyack, NY in 1923. I would love to see some pictures of the restoration. I think at that time there were many boats of this style. Was there a deck or cabin? In a case like this taking the lines is a good thing. Keep us updated.
Gary
"The hand feeds the mind."
Weston Farmer
Old 01-20-2007, 11:51 AM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
Nice looking boat. Very slack bilges. Any idea how much power in that Kermath?
As to taking lines, I'll offer my perspective as a (hopefully) ethical professional designer: I have no qualms whatsoever about lifting the lines from an existing boat provided that:
a.) I have either obtained permission from the designer/owner/builder, or
b.) have exhausted all avenues open to me to obtain the above and documented my efforts to do so, and
c.) I am going to use the lines for scholarly study only and do not intend to financially profit from them nor distribute them to others who intend to profit financially from them.
I find no ethical problems in using the lines from an existing boat as the springboard into a new design "in the essence of", but I give credit to the proginator whenever possible. My most recently built design is based heavily on two 1940's-era Cape Islander boats whose designer/builders have long since passed over the bar. I altered the transom, raised the sheer, and changed the bow profile, but kept the essence of the type. I quite happily call it my design based on a East Ironbound Island type Cape Islander.
Hope for the best, but plan for the worst.
Old 01-20-2007, 12:39 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
Your use of hand drawn lines, with faint lingerings of erasures, re-lettering, re-drawing and possible smudges, while being an excellent rendering, has me wiping imaginary eraser crumbs off my screen and thinking I need to wash my hands. The horror! This day and age calls for CAD pictures where the whole rat's nest is reduced to 3 or 4 thick, jerky lines without much meaning and no information! What were you thinking??
BTW, where would a good instructional be on how to take lines? Sam
Old 01-20-2007, 01:07 PM
Rep: 10 Posts: 42
Sam,
Well...work in progress with regard to drafting - any number of cliches could work - Rome wasn't built in day - gotta break a few eggs to make an omelet. Seriously, the most painful thing is the time it takes to draw this stuff and then to erase say a buttock line is to kiss 45min - 1hr of time away in about 2 sec - a very strong case for CAD.
To take the lines I referenced a Wooden Boat Magazine (August 2002, #167 pg. 34-41) article on using laser levels to aid in pulling lines (and yes, a laser level is what you want, I used a DeWalt self leveling laser).
Also, MMD, it is comforting to hear your rendition of "spring boarding" to your own design as I had my eye on stretching this to 25 - 27ft and not being the scourge of industry. Beautiful Cape Islander - well done. What is the construction.
Old 01-20-2007, 01:10 PM
I drove from LaCrosse a few times to get resin and materials from the University boatbuilding person. An ornery person, I believe styrene and alcohol combined to produce a jerk.
Anyway, there are some boats at this site that vaguely resemble what you drew and the place is only a few miles from where you are. It would be a good day trip and probably some wonderfull bars! Sam
http://www.mainstreetportage.org/Portage%20Canal.htm
Old 01-20-2007, 05:21 PM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
The Cape Islander was built of sheathed cedar strip planking on laminated Douglas fir frames and backbone. Trim and transom is Hondouran mahogany. It is powered by a 54-hp Yanmar diesel. The owner has opted to have the optional traditional-shape cuddy built by the original builder over the winter lay-up.
Old 01-20-2007, 06:13 PM
Rep: 10 Posts: 42
mmd,
I am not sure I understand what sheathes are. Are you talking about a bead and cove cedar consturction with epoxy encapsulated fiberglass with laminated doug fir frames?
Old 01-20-2007, 11:36 PM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
Oops - mistype. Itshould have read, "sheathed cedar strip planking...", as in cedar strip plank (not bead & cove, beveled for flush fit across the full joint - the builder maintains it takes no longer than milling the edges before hand) sheathed on the exterior suface with fiberglass cloth set in epoxy.
Old 01-24-2007, 04:53 PM
Rep: 696 Posts: 1,232
MMD,
At first glance your delightful boat looks a bit like a Pusifer Hampton.
