Old 06-07-2011, 04:27 PM
ancient kayaker ancient kayaker is online now
aka Terry Haines
Rep: 1814 Posts: 3,007
Originally Posted by CutOnce View Post
Some bright light here will recommend hydrofoil assist - that should get it moving faster!
Think about it .... aeroDINK(tm) .... a people's dinghy. With built-in live master bait well and bubbler.
CutOnce
Are you trying to get Doug's attention with those baited words? But Aerodink is a masterful marketing touch . . .
Dances with Turkeys
Old 06-07-2011, 06:38 PM
Poida Poida is offline
Rep: 395 Posts: 1,072
This is called brain storming.
If you get the non functional rubber dingy. Tie it between a tree and the tow ball of your car and stretch it. Then lay it up with fibreglass you would have a sleek kayak.
Now add the skis from boat on skis.
The front rowing system for dingys
The air jet coming out of the back.
Throw in a few more suggestions from different threads and....and...?
Old 06-07-2011, 08:44 PM
aka Terry Haines
Where was that rocket propelled boat . . . ?
Dances with Turkeys
Old 06-10-2011, 12:57 PM
keith66 keith66 is offline
Rep: 117 Posts: 223
If you manage to pump the thing up with a compressor & air line just hope it doesnt burst, it could cause a lot of damage. Many years ago at Thames marine one bored lunch hour some of us hooked an elbow length black rubber glove to an airline, it swelled to a prodigous size until it resembled a mishapen naval mine with five horns like cucumbers. It actualy held the 105 psi in the line. At this point we realised it was not going to go on its own so somebody threw something sharp. The resulting blast nearly deafened us & shifted a mirage 28 yacht that was nearby several feet sideways. Happy days!
Old 06-10-2011, 09:29 PM
sctpc sctpc is offline
Rep: 30 Posts: 10
Hahahahah Ive done that it makes your ears ring for days arr it brings back the memory's
Old 06-10-2011, 09:43 PM
whitepointer23 whitepointer23 is offline
Rep: 247 Posts: 652
yes i know how dangerous air pressure can be , but i would do it under controlled conditions, like hang it over the fence . i don't want to be rude but are you sure an exploding glove moved a 28 ft boat several feet.
brendan .
Old 06-10-2011, 09:59 PM
aka Terry Haines
If it actually stalled a compressor at 105 psi it could have a great deal of energy, but I find it surprising too.
Dances with Turkeys
Old 06-10-2011, 10:19 PM
Ancient Kayaker, the compressor wouldn't have stalled. Either a pressure switch would have turned it off at 105psi or the unloading valve would have engaged and the compressor would still run but not pump.
Old 06-10-2011, 11:28 PM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
You should Google "Bull Frog" boats.
  #25
Old 06-10-2011, 11:49 PM
Rep: 247 Posts: 652
just had a look at the bull frogs, we have similar boats here, fibreducks and allyducks.
brendan .
Dinghy Rudder Change on Kite Dinghy BobBill Sailboats 1 09-02-2010 04:03 PM
My first Dinghy MrMahogany Boat Design 13 08-26-2010 01:52 PM
Dinghy JFF7 Sailboats 2 07-16-2007 03:37 AM
Best Dinghy? mackid068 Sailboats 30 03-21-2005 08:03 PM
D4 Dinghy? Guest Boatbuilding 2 06-05-2003 02:39 PM
