Old 11-13-2009, 07:32 PM
CenkA CenkA is offline
Rep: 10 Posts: 11
Do you have something to say about "Jinx" ?
I want to build Jinx. What do you suggest me about building steps ?
Old 11-13-2009, 10:47 PM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 681
Not sure..............
Not sure what you mean actually.
Is there a link to plans , looks like an older design of conventional plywood on frame construction , which is quite straight forward. Should be easy and quick to build ( small boat ).
Old 11-14-2009, 01:56 AM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
Is this the plan/article you are working from?
http://www.svensons.com/boat/?p=Mech...lustrated/Jinx
Old 11-14-2009, 03:40 PM
Rep: 10 Posts: 11
I asked general information about "Jinx building".
If anyone had build Jinx before,maybe he/she could give me suggestion about building steps !
Specially i can say;
Is it possible to make each frame only one-piece from 12mm plywood ? i don't want to make old-style frame.
Old 11-14-2009, 06:27 PM
Rep: 1493 Posts: 7,447
Plywood frames are weak for their weight. Half the fibers are in the wrong direction.
Old 11-14-2009, 08:53 PM
boat fan's Avatar
Rep: 357 Posts: 681
Similar boat
Not sure that there are any benefits to building plywood frames .
This link may help , it`s not a jinx , but the build is very similar process.
http://www.glen-l.com/methods/plywood/mthdpw01.html
Hope it`s of help.
Old 11-15-2009, 12:05 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Sure, use well mixed epoxy and lots of stainless steel screws.
Old 11-15-2009, 06:30 AM
Rep: 10 Posts: 11
Jeff, i am sorry;yes plans are from svensons.com.
If Plywood frames are weak ,Maybe i can use foam sandwich method.
8mm DIAB foam +biaxial fibers+epoxy resin.Sandwich method building ,is good enough for the frames ?
boat fan thanks for the link.It is similiar with Jinx...
Old 11-15-2009, 07:56 AM
apex1
No,
the foam is even weaker than ply, much weaker! Though it has its benefits and for panels it may be good, but not for frames.
Stay with the original ply frames, if they are specified, there´s nothing wrong with them.
Regards
Richard
Old 11-15-2009, 09:15 AM
Rep: 10 Posts: 11
Whatabout vacuum infusion process !.
If i manufacture frames with vacuum infusion method .Is it again weaker than ply ?
Old 11-15-2009, 09:24 AM
BertKu BertKu is offline
Rep: 130 Posts: 1,035
Yes, I would make it electric if I were you.
Old 11-15-2009, 09:42 AM
Rep: 10 Posts: 11
Electric for this little boat ! i think it is too smal for electric boat...
Old 11-15-2009, 11:01 AM
Mariner
Definitely electric, with a flex drive, a big prop and lots of expensive
batteries (LiPo). Don't forget to plug it in when you get home!
-Tom
Old 11-15-2009, 11:22 AM
Just borrow a torqeedo motor with Lithium batteries for a demo.
refer: http://www.torqeedo.com/us/hn/produc...ebersicht.html
Bear in mind an electric motor is much more efficient. A Torqeedo 1Kw motor is approx equivalent to a 4 Hp outboard. Your boat will be ligther also.
Old 11-15-2009, 12:17 PM
apex1
Bert
borrow in Turkey??? Stealing is simpler!
What do you think is vacuum infusion Cenk? Does it infuse strength into a weak material? Or maybe just resin?
shouldn't optimized designs be "salt" OR "fresh" water? Squidly-Diddly Boat Design 4 09-14-2009 01:17 PM
16-18' "Sit-in" Planing Monohull ("Trapwing") Doug Lord Sailboats 124 04-23-2009 05:14 PM
CMD "project Zeus" VS VOLVO "IPS" gerard baladi Pod Drives 13 09-10-2007 09:23 PM
Boat "workshop" including a "testing tank" zmfmd Open Discussion: All Things Boats & Boating 0 08-08-2007 04:43 AM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 02:03 PM
