Old 09-18-2011, 06:20 PM
Thames Thames is offline
Rep: 15 Posts: 9
Location: Thames Valley, United Kingdom of Great Britain and Northern Ireland
Do some boats have a cabin but no sole or floors?
I was taught by a boat builder that you can't just walk around on a bare hull - boats need a cabin sole and some flooring to spread the weight of the crew, and to make the whole structure more rigid.
However I have now seen some respected designs for microcruising boats that have no sole or flooring. I've included photos of each build to show that they have no cabin sole.
First Matt Layden of Florida's Enigma 360 - stitch and tape 9mm/6mm plywood glassed, displacement c.420lb, LOA 12' beam 3'3" draft 6".
Do some boats have a cabin but no sole or floors?-enigma_build_stitching.jpgDo some boats have a cabin but no sole or floors?-enigma_build_stitched.jpgDo some boats have a cabin but no sole or floors?-enigma_360_cabin.jpgDo some boats have a cabin but no sole or floors?-enigma_360.jpg
Second Sven Yrvind of Sweden's latest boat which he has just sailed from Ireland to Madiera. It has a 2" thick foam core in a fibreglass sandwich. 16' LOA, 4'3" beam, ~10" draft, displacement c.1800lb.
Do some boats have a cabin but no sole or floors?-yrvind__build_hull.jpgDo some boats have a cabin but no sole or floors?-yrvind__build_lockers.jpgDo some boats have a cabin but no sole or floors?-yrvind__build_cabin.jpgDo some boats have a cabin but no sole or floors?-yrvind__build_cabin_1.jpgDo some boats have a cabin but no sole or floors?-yrvind.jpg
Matt Layden's only published design is the Paradox which does have a cabin sole. It's roughly 14' LOA 4' beam 9" draft displacing 1400lb:
Do some boats have a cabin but no sole or floors?-paradox_sketch.jpgDo some boats have a cabin but no sole or floors?-paradox_sketch_profile.jpgDo some boats have a cabin but no sole or floors?-paradox_sailing.jpg
How can the boats with no cabin sole be strong and rigid? Possible explanations:
  • they gain extra rigidity from the convex shape of the planking, and they all have some rocker
  • they only have approximately 3' headroom so crew must sit on the hull, spreading the weight more gently
  • they're narrow beam so the unsupported surface is not large
  • Yrvinds boat is a 2" thick foam core sandwich so this may add extra rigidity and spread point loads
Are there any guidelines for the size of boat that can be built like this?
Old 09-18-2011, 06:36 PM
Lister Lister is offline
Moxy
Rep: 45 Posts: 172
If the plan show the crew walking on the inside part of the bottom planking, they are not "Respected designer". Keep this term for real designer.
Lister
"I always like walking in the rain," he said, "so no one can see me crying."
Charlie Chaplin
Old 09-18-2011, 06:39 PM
Rep: 15 Posts: 9
They don't walk on the inside of the bottom planking because there is no standing headroom, they can only sit. But they can stand if they have the hatch open.
Old 09-18-2011, 06:40 PM
Mick@itc Mick@itc is offline
Rep: 32 Posts: 74
No sole...
Hi
Bob Oram's designs have no sole in the hull cabins and he is an excellent designer. He is a minimalist in terms of design and reduces his design to what is needed, no more. This results in a comfortable and easy to sail cat.
Mick
Old 09-18-2011, 06:50 PM
philSweet's Avatar
philSweet philSweet is offline
Rep: 658 Posts: 621
Lister
Well, this ought to get some people's attention. I would submit Bill Crealock's Clipper Marine designs as a counter example. Not my personal favorites, mind you.
Old 09-18-2011, 07:11 PM
viking north viking north is offline
Rep: 727 Posts: 1,161
On our grand banks dorys we walk directly on the floor --it all depends on the rigidity of the material used. 2 in foam core is certainly rigid and warm also especially in these North Atlantic waters.
Old 09-18-2011, 07:13 PM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
Some comments below.... in red.
Yes, some rocker will make any flat surface stiffer. Don't forget the arch from architecture. Although, thinking about it a bit more, the "arch" of rocker is upside down and not contributing to stiffness at all, except stiffness against external water pressure.
This is probably the biggest reason. Try making up a sheet of something with an adequate skin on it and 2" of 6lb Corecell. You could drive a tank over it and it wouldn't break.
"You can't solve all of life's problems with epoxy" - My Wife
Old 09-18-2011, 08:36 PM
Rep: 15 Posts: 9
Thanks for the useful comments.
It would seem that the rocker combined with the bend in side panels stops the boat flexing around as much as a cuboid shaped hull and gives it more external strength.
But the 2" thick foam core sandwich construction will enable the hull to take more point loads from the inside (as well as increasing strength for external point loads and overall stiffness).
It's amazing how the Enigma 360 can take the loads on the inside, having only a 9mm plywood bottom with no added support. It must be ok because it was one of the first finishers in the Ultimate Florida Challenge, a 1200 mile coastal/river race around the whole of Florida. I suppose it is only 3'3" wide so perhaps can go unsupported.
Old 09-19-2011, 03:27 AM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Lister
Some of Phil Bolger's designs use the inside of the bottom as the sole. Guess he's not a real designer.
Old 09-19-2011, 11:05 AM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
That would be a problem only on a very light boat. My 16' open outboard was designed to walk on the inside of the hull. Works fine if there's no water in the bilge or if one has boots on. Floors are mostly to keep your feet dry or to provide a flat surface to stand on or (usually) both. Later models of this boat have flat floor boards.
Old 09-19-2011, 12:03 PM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
Floors on traditionally built watercraft also tied the frames and keel together. They carry tension loads from the frames and bear the keel loads, tranmitting the loads to the frames and thus to the planking. The added benefit was that you could add your cabin sole to the topsides of the floors. Point loading on traditional hull planking is to be avoided. Todays sheet materials can handle point loading a whole lot better than pieced together plank hulls. Granted, point loading needs to be acounted for in the hull scantling.
LP
God bless the open minded people of the world. LP
Old 09-19-2011, 12:21 PM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
Most (not all but most) of the boats that don't have floors have other structure filleted in (bulkheads, bunks, lockers etc) that reduce the amount of open area (span) that carries the load. Added to that...a point load on a curved piece of sheet material fixed by vertical members (basically an open topped box with a curved bottom) isn't going to cause the sheet to form a compound curve...it usually can't. The one exception is when torturing the ply and that is done during construction using very thin materials.
Old 09-20-2011, 08:10 PM
Moxy
Rep: 45 Posts: 172
I don't consider him a great designer, but yes he was real designer.
Walking inside the bottom on a offshore sailing boat is not a good idea. On a plywood epoxy sharpie going around the pound it is an other story.
Lister
Charlie Chaplin
Old 09-21-2011, 02:48 AM
PAR PAR is online now
Rep: 3125 Posts: 9,398
Lister, Bolger was one of the greats, with nearly 700 designs to his credit. Unfortunately, he's mostly known for his eclectic nature and square, common man's designs, which is sad really, considering the volume and scope of his work.
The use of a sole is largely a matter of available space. A 16' pocket cruiser, carrying a 150 square ft. sail plan and a small cabin to hide from the rain, can't afford kissing off several inches of sitting headroom, just to have a proper sole. An 18' powerboat cruiser with a cuddy, may just have enough internal volume, particularity if it's round or V bottomed, to warrant a sole.
As to it being a good idea to walk on the planks, well, yes and no is the answer. If you have a relatively small, traditionally built lapstrake or carvel, you should try to keep you feet on the frames or stringers. These planks weren't intended to bear weight in this fashion and you could easily pop fasteners, if not actually crack a plank. On the other hand, this type of build would likely have some sort of sole, be this a simple grating or slates over the frames or a full blown sole.
Conversely, many small craft are intended to have the bottom planks walked on. I have several designs just like this and the additional loads this imposes was considered in the scantlings, during design development.
It's difficult to second guess the engineering approach a designer may have incorporated into a particular project. I have a design that Eric is familiar with, that has the crew walking directly on the bottom planks. The boat is a rock under foot, underway or at rest and this was my intention when I drew it up.
Lastly, the old builder that told you that walking on the planks was wrong, is correct, sometimes. Bundling designers into a lump, because they don't meet his expectations, is a rather narrow minded, if absurd view and should be taken with a grain of old salt. When he was a lad, this was very true, but modern building methods have surpassed even this guy's expectations, so he needs to try to keep up at the very least or qualify each comment like that with a "in the old days" prefix.
Old 09-21-2011, 03:08 PM
BATAAN's Avatar
BATAAN BATAAN is offline
Rep: 1090 Posts: 1,502
It seems that one is sitting in the bilge, so the least bit of H2O and your pants are wet and your sleeping bag.
Sole/floorboards separate the wet bilge from dry feet one would hope.
Flexible closed cell foam liner would substitute, getting you a little out of the wet.
But if your boat is tiny, eliminating all but the absolutely necessary is kind of like an ultralight airplane in that you leave everything off but what you really need, and some boats don't need floor timbers or a sole, but most benefit from them.
Cabin Sole as a structural member? Pylasteki Sailboats 13 12-20-2008 03:39 AM
24' cruising sailboats- how far is the cabin sole below the waterline? Seafarer24 Sailboats 3 10-10-2008 10:32 AM
Warped cabin sole GWB Wooden Boat Building and Restoration 9 09-08-2008 10:35 AM
Hatch trim for cabin sole 1soleman Wooden Boat Building and Restoration 0 07-29-2006 01:54 AM
Soundproof cabin sole Willallison Materials 3 10-03-2005 08:01 PM
