Old 10-26-2006, 10:25 PM
naturewaterboy naturewaterboy is offline
Steel Drum Tuner
Rep: 10 Posts: 209
Displacement Hull Speed of a Tuna
What have we learned about boat hull design from studying how fish swim?
Wherever you go, there you are...
Old 10-27-2006, 02:39 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 302 Posts: 2,318
Submarines and airplanes are easier to design than boats. They operate in just one medium and you don't have to consider wave making (as long as you are in sub sonic speed).
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 10-27-2006, 03:10 AM
yotphix yotphix is offline
Rep: 16 Posts: 45
Nothing from fish but this from dolphins! (hope i uploaded that right)
Old 10-27-2006, 03:12 AM
Rep: 16 Posts: 45
i think that's right
Old 11-03-2006, 10:21 PM
Steel Drum Tuner
Rep: 10 Posts: 209
So why not put a big fish shaped hull under the boat (and make it wiggle like a fish) and stick a boat on top of it out of the water?
Old 11-04-2006, 03:12 AM
Rep: 529 Posts: 1,599
Keith
If you have ever watched salmon running up a fall or race they get up on the surface of the water and drive with their tails cause they can't swim against the current submerged. A bit like a planing power boat. They would benefit from an inboard engine and a jet drive
Seriously though we have little to learn from fish for surface craft and earlier hullforms based roughly on fish shapes were less than ideal resistance wise.
We can improve on most fish shapes for submerged vehicles. However even optimised shapes are far less efficient than surface craft due to a big wetted surface drag penalty, also operating so close to the surface would also add a substantial surface wave.
Cheers
Mike Johns.
Old 11-04-2006, 05:49 AM
Raggi_Thor's Avatar
Search for SWAT :-)
www.MBOATS.no
Old 11-04-2006, 06:19 AM
Robert Gainer Robert Gainer is offline
Designer/Builder
Rep: 40 Posts: 142
And yet we have a lot to learn from the surface of the dolphin. The skin has a texture and flexibility that enhances speed without adding the need for power. I have often thought that a hull with flexible bladders to change the shape and built of dolphin skin would be great. Imagine a sailboat that had a lifting foil shape that changed on each tack. No leeway at all. Or a hull that had the ideal PC for all speeds.
Robert Gainer
Old 11-04-2006, 06:25 AM
Originally Posted by Raggi_Thor View Post
Search for SWAT :-)
SWATH is stability oriented definately not for speed.
Mike Johns.
Old 11-04-2006, 06:36 AM
Originally Posted by Robert Gainer View Post
And yet we have a lot to learn from the surface of the dolphin. The skin has a texture .......................Imagine a sailboat that had a lifting foil shape that changed on each tack...........
I read that they appear to detect and prevent seperation keeping laminar flow and consequently low drag.
I really doubt that we can use their technology which ultimately is very complex and consequently very hard to make durable reliable and affordable.
Twin lifting keels/daggerboards angled for windward lift work well too.
Cheers
Mike Johns.
Old 11-05-2006, 03:53 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 933 Posts: 3,638
That we really can't duplicate it.
A boat has to carry load, and a submarine has to maintain an atmosphere inside it. Fish don't carry loads and they adapt to ambient pressure. Fish have hundreds of muscles behind a flexible skin, and can bend and flex as they please; human-made materials tend to prefer rigidity. Fish have some interesting techniques, but they're solutions to a very different problem than that of the boatbuilder.
-Matt Marsh-
Old 11-06-2006, 04:25 AM
Raggi_Thor's Avatar
Imagine a sailboat that had a lifting foil shape that changed on each tack. No leeway at all...
I think this is a popular misunderstanding.
Why do you want "no leeway"?
www.MBOATS.no
Old 11-06-2006, 06:00 AM
Designer/Builder
Rep: 40 Posts: 142
Raggi_Thor,
It was my understanding that to prevent sliding sideways a keel or other surface was added to the hull. This worked by have an angle of attack which generated lift and drag. If you used a lifting surface to prevent leeway and it didn’t have the same amount of drag then more energy goes to making progress. Leeway is just a waste when you are trying to work to windward but it’s the drag I was really trying to reduce. Maybe not the best choices of words but you get the idea.
Robert Gainer
Old 11-06-2006, 07:42 AM
yipster's Avatar
yipster yipster is online now
Rep: 443 Posts: 2,636
i only half agree, stability yes and not high speed but think u-boats and check navy swaths, they are way over their hullspeed
Old 11-06-2006, 10:28 AM
Excalibur Excalibur is offline
Rep: 10 Posts: 23
In regards to SWATH hulls... If you design the underwater body to get the CG as low as possible and maybe add a ballasted keel, could you get enough stability to go to a monohull? Its true that such a design would have very limited deck area, but if one was williing to put up with that in return for a high displacement speed, would it work?
Displacement Hull Speed calculation Toby P Boat Design 11 01-14-2006 04:42 PM
Power/Speed/Displacement Calculation NB Willawaw Boat Design 12 12-29-2005 07:23 PM
Increasing speed w/ semi-displacement hull 67-LS1 Boat Design 17 12-11-2005 11:32 AM
Hull speed for Displacement hulls jameshogan Boat Design 5 06-14-2005 12:21 PM
Displacement vs. Comfort vs Speed michael puig Sailboats 9 06-13-2004 03:32 PM
