| In regards to SWATH hulls... If you design the underwater body to get the CG as low as possible and maybe add a ballasted keel, could you get enough stability to go to a monohull? Its true that such a design would have very limited deck area, but if one was williing to put up with that in return for a high displacement speed, would it work? |
| Holy Gadzooks! I only hit the send button once, promise! |
| Marshmat has it spot on. We tend to design for rigid materials, which fish aren't. As has been said before, surface vessels operate in a different medium to fish, in as much as they are in the air/water interface. That significantly changes the problem as there are now waves to contend with. Submarines are sort of similar to dolphins/whales etc but the practicalities of design mean that you can't copy a dolphin design carte blanche. Most modern subs have moved away from the tear drop shape, due to the difficulties of fitting all the maachinery in. The US Navy (amongst others) has researched flipper propulsion, and it does have some advantages over rotary propulsion, but it would be nih on impossible to make a full size sub with ths sort of system. I dispute the comment that submarines are less efficient due to their higher wetted surface area. An attack sub (albeit nuclear powered) can definitely outsprint a frigate. |
i did some model testing with swath and -very delicatly- it does work ![]() |
| i did some model testing with swath and -very delicatly- it does work Looks something like the General Dynamics proposed LCS. By "very delicately" do you mean that it only works with small sea states, or that you are not willing to get further into the design? Just curious. I was thinking of an actual monohull with no outriggers. Kind of like a WWII submarine when surfaced deck awash, with a hull width much greater below the waterline than above. I note that they had a length/beam ratio in the 10:1 area but had sufficient roll stability. Oh, and as far as an attack sub out sprinting a frigate, very apples to oranges there. The frigate's prop will cavitate MUCH sooner than the subs due to the compressability of sea water at atmospheric pressure (lotsa air bubbles near the surface). Not a fair contest at all. |
| excalibur, a 2 ft model of this drawing i tested. speed ( reduced wave resistance ) and stability in wild water worked fine, trick was calculating volumes for the pods and keels together with displacement and cg and than load must be centered on deck still, works and is exiting but not as easy as it looks. have those legs 4 ft high made but need the framing etc to have a real live go. together with our other boat its the short money that slows it up. i looked up lcs but dont think it is a swath while general dynamics / lockheed martin is into those also. surfaced subs would be great freighters but forget now what was against them. |
| Robert, I think what you can save in drag is overestimated. Look at the many boats with rotating keels or keels with flaps (rudders) to increase lift so the boat travels with no leeway. These boats are not necessarily faster than others in the same class. |
| OH boy, there is a lot of fluff flying in this thread. A target rich environment. 1) Quote:
2) Quote:
3) Quote:
4) Quote:
5) Quote:
| Displacement Hull Speed calculation | Toby P | Boat Design | 12 | 04-10-2011 06:29 AM |
| Power/Speed/Displacement Calculation | NB Willawaw | Boat Design | 12 | 12-29-2005 07:23 PM |
| Increasing speed w/ semi-displacement hull | 67-LS1 | Boat Design | 17 | 12-11-2005 11:32 AM |
| Hull speed for Displacement hulls | jameshogan | Boat Design | 5 | 06-14-2005 12:21 PM |
| Displacement vs. Comfort vs Speed | michael puig | Sailboats | 9 | 06-13-2004 03:32 PM |
