Old 10-22-2011, 07:46 PM
JordieS JordieS is offline
Rep: 26 Posts: 89
Displacement Catamarans
Hello everyone,
I've recently taken an interest in displacement catamarans, and I am currently doing a bit of research as I may design a 6 metre displacement Cat.
I am interested in them because they can go quite fast with relatively little power. Somewhere on the internet someone said they could go 10 knots in a 20ft displacement Cat with 6hp, does this sound reasonable? Do you think it is possible to get a 6m displacement Cat to do 15 knots with 15hp? or just 10 knots with 15hp?
Thanks
Old 10-22-2011, 07:53 PM
sabahcat's Avatar
sabahcat sabahcat is offline
Rep: 257 Posts: 793
yes, if you just want hulls and want to travel on the perfect day
But what else do you want it to do?
carry a house and a load, then probably no
Old 10-22-2011, 08:05 PM
Rep: 26 Posts: 89
The boat will just be a small runabout, no cabins or anything just a few seats for 7 people or so.
Old 10-22-2011, 08:27 PM
Ad Hoc Ad Hoc is online now
Naval Architect
Rep: 1925 Posts: 3,024
Make sure you L/B ratio is above 10, preferably closer to 15~20 L/B ratio. Then your L/D (length displacement ratio) by default should also be good. Just don't have the 2 hulls too close together...too much interference effects.
Old 10-22-2011, 08:40 PM
bertho bertho is offline
bertho
Rep: 45 Posts: 143
Jordies,
be aware than cat have more or less two time the hull area as a monohull have (deck area + 2 hull area, and need to achieve around the same displacement as a monohull to perform, so the material need to be two time lighter than what you will use for a monohull... for identical or better strength as the platform will have more stress, so, be ready to spend more $$ on the hull construction to have a good result.
all the best
bertho
creating and building simple boat is much more difficult than complicated ones.....
Old 10-22-2011, 09:04 PM
Rep: 26 Posts: 89
Bertho, correct me if I am wrong but a displacement Cat is faster because it's hull's can be thinner than a monohulls and since it is a displacement boat weight is not as important for speed as the boat does not produce dynamic lift.
Old 10-22-2011, 09:19 PM
Richard Woods's Avatar
Richard Woods Richard Woods is offline
Woods Designs
Rep: 976 Posts: 691
Have you seen my Skoota powercats?? See my website for more
eg Skoota 20 : 20ft, 25hp, 2 berth, 15 knots, 10mpg. Trailable
I don't think you'll do 10 knots with 6hp, but you will with a 9.9
Remember that 7 people weigh about 500Kgs, so more than the weight of the empty boat
Also remember that the engine will weigh more than one hull (one hull say 150lbs, one 25hp outboard near 200lbs)
www.sailingcatamarans.com
Old 10-22-2011, 10:47 PM
bertho
Rep: 45 Posts: 143
jordies,
with a "displacement catamaran" hull, if you double the volume to move on the water, even with a better ration length /beam, will be like two "better shape" hulls to move instead of one, two time wave resistance + interaction/slimming pb between the hulls as said ad hoc, two time friction area, ...no miracle.. especially with only 6 meters waterline, look perhaps for a longer waterline with slim hull, or built your cat very light !
bertho
Old 10-23-2011, 04:19 PM
gordanm's Avatar
gordanm gordanm is offline
Rep: 20 Posts: 17
I'm also interested in design similar to what JordieS describes. For long time I've been searching internet for such design and but had no luck so far. My preferrable deck layout would be something similar to Bayliner 197 SD deckboat () http://www.bayliner.com/_eumeaf/index.php?content_id=5367&boat_id=38 . I would also be happy with 10 HP engine and max load of 4 people. Basicaly something similar to Jarcat 6 but without the cabin. Does such design exist and if not, what would be the possible reason?
Semi Displacement at displacement speed HowardH Boat Design 23 12-23-2010 07:35 AM
Displacement or Semi-Displacement Hull waynep Boat Design 24 10-05-2010 09:01 AM
Displacement catamarans and single hull power. Typhoon Boat Design 11 04-10-2010 05:06 PM
Catamarans: 2004 Sales Report for New and Used Catamarans catamarans Press Releases 2 08-04-2004 11:24 AM
Catamarans: 2004 Sales Report for New and Used Catamarans catamarans Press Releases 1 06-10-2004 03:53 PM
