Old 02-22-2007, 08:21 PM
benmww benmww is offline
Rep: 10 Posts: 10
Dingy with no longditudals
Hi everyone
I'm building a 3.5metre dingy that has no hardwood in the entire thing!
just plywood
it also has no longditudals and I'm wondering how doI hold the shape together while putting the plywood planels on the frames
or maybe i should stich and glue the planel and then add the frames second
any help on the topic at all would be great
I designed the boat's structure based on a scull/sailing dingy called oxygen
it was at some of the wooden boat festivals as well
Old 02-23-2007, 06:56 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Can you erect the frames on a temporary backbone?
For thin plywood skins some longitudinal stringers make the building much easier.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 02-23-2007, 04:50 PM
Brands01 Brands01 is offline
Rep: 20 Posts: 102
If you know the shapes of the panels, you can stitch along the chines/panel edges. If the panel shapes are correct, you can bend your panels around your transverse frames and everything should meet up.
Check out this tutorial for some ideas
http://bateau2.com/content/view/120/28/
Good luck!
construction drawing mirror dingy sass Boat Design 6 10-16-2009 03:59 PM
dingy sailer's benmww Stability 9 01-16-2007 04:49 PM
Sugestion for thrilling Sailing Dingy Yacht Skipper Sailboats 24 08-05-2006 04:01 PM
What is a good proven dingy motor...? paularey Sailboats 9 01-26-2006 01:39 AM
15 dingy sailer? Brad Sailboats 0 10-08-2001 11:52 PM
