Old 04-02-2004, 09:00 PM
genecoul genecoul is offline
Rep: 10 Posts: 2
dimensions of planking material
I've got an Artesania Latina Endeavor for which I've nothing to measure the various pieces of planking. I've not got any knowledge of millimeters so I need some help. Here are the dimension of a few planks that which I have that I can't tell one from the other:
0.6x5x135 - Fore and aft step planking
0.6x5x110 - Forecastle deck planking
0.6x5x170 - Waist deck planking
0.6x5x300 - Poop deck planking
Can you tell me what each of the dimensions mean. I've got a ruler that contains millimeter dimensions but I can't seem to determine the differences.
I appreciate any and all help any of you may be able to provide.
Thank you.
Gene Coulson
Old 04-03-2004, 03:25 AM
Suede Suede is offline
Registered
Rep: 10 Posts: 32
Hi, if size is millimeters it would be:
0,024x0,2x5,4 inch
0,024x0,2x4,4 inch
0,024x0,2x6,8 inch
0,024x0,2x12 inch
wich doesn't make sence unless your building a model ship.....
To convert millimeters to inch you just divide by 25 as 1 inch = 25 mm (or 25,4 to be exact).
Old 04-03-2004, 06:52 AM
Rep: 10 Posts: 2
Suede,
Yes, I am building a model, the Endeavor. Is the last or larger dimension the length or not. You see, with the dimensions I've got in the kit I'm not sure whether they are width, depth or length. The majority of what I call planking is basically all the same length. Thanks.
Gene
Old 04-03-2004, 07:55 AM
TheFisher TheFisher is offline
Registered
Rep: 60 Posts: 83
Plank thickness X Plank width X Plank length
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
boat material / furniture material bogeyinthekeys Materials 7 09-10-2005 09:29 AM
Strip planking vs wide planking jfblouin Wooden Boat Building and Restoration 26 08-11-2005 10:00 PM
plywood vs strip planking jfblouin Materials 2 03-08-2005 03:55 PM
