| i did read all i could find on stepped bottoms for decades, it took a long time to get the R&D right, poor stability caused again un-predictable steering some major power boat producers called it a marketing hype and stay'd with un-stepped hull's and some still do |
| I own a Wellcraft Airslot (1971) that was one of the first stepped hulls as I understand. The goal of the designer (as explained in his successful U.S. patent) was to achieve better on-plane performance, not higher overall speeds. I can attest that this vessel comes onto plane very easily without any bow high attitude during initial acceleration. The step is shown at item "S" in the patent drawing. The theory is that as the boat begins to advance under power the waterline under the bow creeps back as the bow raises. When the waterline meets the step the bow drops back down to a comfortable attitude during the rest of the acceleration phase. It really works. I've owned many boats and this boat performs remarkably in this regard. This hull also had unique sponsons that provided incredible stability and a cleft lip so to speak at the bow that does a great job of knocking down spray. It appears to be a forerunner of the Whaler hulls of later years. |
Yet what appears to be the same boat can easily do 80mph without issue. I am trying to take that hull to 105 mph, and the designer says I can do so. I believe him, as I have experianced three versions of stepped hulls, and his is completely stable. The other hull is a Lorne campbell designed 32 footer, same sort of step configuration - not as stable as the B24, but much more stable than the Honda race boat. Possibly the engines/weight/setup have something to do with it, but I can clearly see that what looks to be the same design is really very very different when you push its limits. For information, Occe Mannefeld designed a B28 and a B23 which were different versions of the stepped hull. All look similar. The B24 hull was the lastest, and best. The B28 can not go much over 95 without getting really edgy, despite being longer and wider. So he has learned and he has improved. I would look in his direction for answers, as it is my belief that he has 'cracked it'. |
| no doubt Occe Mannefeld designed a great boat with the B24 and almost all new speed boats nowadays have stepped hulls never was faster than 55 "land" miles wot myself, fast enough tho to see size does matter in chop and inland speeding getting very restricted did not see that Wellcraft Airslot before and still am fascinated seeing hullforms |
| Hi Yipster, My thoughts here were that not all stepped hulls are created equel, even those that appear to be similar. So an experiance of one stepped hull should not be the defining characteristic for the whole class. Even from the same designer, earlier models were not up to the same 'standard'? as later versions. Speed is ( for me ) the defining characteristic in a boat. But speed without control is worthless. Beauty ( for me ) is in the speed and handling in the water, and being able to handle all conditions well. I always thought that if I was serious about understanding why stepped hulls work well, I should go to the person who has done it right, rather than look at all the designs that exist. To be honest, I have spend a load of time underneath both of my stepped hull boats, measuring and even making moulds from the hull to bring in the lounge and try determine why one works so well, and why the other does not make the grade. The differences are subtle, and I fail to see why they should make so much of a difference. Obviously I am not the person who should be doing the investigation, rather someone who understands the concepts should do so. I hope to understand one day what makes one hull better than the other. I would love to get hold of your information on stepped hull design. Marc |
| Marc, understand your a speedster and in much i agree, interesting to hear your findings similar to things i heard before the white water, reduced resistance a planing boat gets from cavitation i could simple answer but there is quit a bit more on this forum and a search shows lots of good info most history and theory i got is throu many years of reading boatingmagazine" (see they also have a forum now ) and other publications. get also profesional boatbuilder magazine free with articles on the subject by pro's by no means do i pretend to be an expert here but see you want to be the customer and the designer at the same time but i understand couse as i heard before, stepped hulls are verytricky |
| Interesting conversation you have. When we talked to that guy he told us that if WATER removes the air below the "step" it will occur a great speedreduction. So for safety we should install safebelts on every step-bottom:ed boat. And it might be better because people will buy safer boats, right? |
| there are lanyards and live jackets on all fast boats, dont really know if safety belts would be good race pilots get catapulled out sometimes, perhaps better than uncontious beeing strapped in while upside down? canopy boats probably keep you in but dont know much about belts with oxigen masks ![]() |
#25
You can run an air system that only supplies air when it is under water, and it is over your face the whole race - But I am not happy with that, as it is uncomfortable. My thought was - being thrown out of my boat at 80 mph and hitting the water, or worse, staying in the boat like Victory at Cowes and hitting the water.... Or being securly strapped to the boat, and crashing with the boat, waiting for the canopy to flood, then escaping. I have seen two crashes in my racing time. In one crash, the guys were canopied, and they got out and helped recover their own boat. In the other, the crew suffered two broken collar bones and a broken leg. Both were in hospital for over a week. As for the guys who go over 80mph - I think that is madness not to have a conopy. The UIM agree - they ban the P1 boats from exceeding 90mph, whilst they allow unrestricted speeds in the canopy classes. |
#26
| kursinal;110790, "it wont be fun if u go from 50 mph to 30 mph in less than a second" dont know how much stepped hull drag climbs while slowing down do know coming of plane better be done gradually anyway verytricky, thanks for the canopy and IUM info anyone with an opinion on standing behind the wheel going fast? |
#27
| Yeah, make sure you wear the "kill switch" like on a PWC |
| differences between nitro hull and vee pad hull | riveramunizaga | Boat Design | 4 | 05-24-2005 10:27 PM |
| what is faster a flat boat hull or a vee pad hull | riveramunizaga | Boat Design | 24 | 05-24-2005 02:18 PM |
| hull boat redesigns (hull pad project) | riveramunizaga | Boat Design | 9 | 05-12-2005 08:35 PM |
| Stepped Hull Designer for evaluation of hull | lpsco1 | Powerboats | 2 | 08-18-2002 07:21 PM |
| Hull or hull & deck broke apart during 40-50 mph turn | Jeff | Powerboats | 1 | 07-09-2002 12:27 AM |
