Old 09-14-2007, 05:33 PM
Jasper_ghost Jasper_ghost is offline
Rep: 10 Posts: 16
difference 15/20 degree V
I consider a 26 feet cabin cruiser aluboat (precut) trailerable mainly to be used inshore and in calm to medium rough sea and powered by a 300hp outboard. Purpose is diving and fishing so also some anchering and trolling. Please comment or correct me if im wrong
So far i think a 20 degree hull is a good choice to give a smooth ride in medium rough sea. But Im looking for experience/good advice with 15 degree contra 20 degree design. What is the pros/cons with regard to:
stability
planning/cruice/max speed
mpg.
other
Will 20 degree be unstable when anchoring, and how important is it to keep COG low.
Thanks,
Jasper
Old 09-14-2007, 06:06 PM
Gilbert Gilbert is offline
Rep: 28 Posts: 512
Sorry to say I do not have the exact data that you are looking for but I can give you my recommendation.
I would say you have chosen a very nice size boat for the purposes you mention. A 26' boat will make a reasonable speed while not planing in very bad conditions. A 15 degree deadrise bottom will give you a lot higher feul efficiancy than a 20 degree deadrise. The top speed you can achieve with 300 hp will be much higher also. Personally, I would prefer even less than 15 degree deadrise to gain even more efficiency and the potential for more top speed, but you did not ask about that option. And with all this I must say that the deeper veed hulls can provide a quite smooth ride in some pretty nasty chop, but they too will have to slow down at some point as the conditions worsen.
Old 09-16-2007, 02:10 PM
Rep: 10 Posts: 16
good point, tks. Does any have a rough idea of the % increase in mpg or top speed for the 15/20 degree?
Old 09-18-2007, 12:09 PM
fastwave fastwave is offline
Rep: 36 Posts: 73
If you consider the change in V changes the vertical component in hydrodynamic lift then the difference is only 3% in lift from 15 to 20 deg.
Old 09-19-2007, 12:01 AM
Rep: 28 Posts: 512
If you are suggesting that a boat with 20 degree deadrise would only use 3% more fuel than an otherwise similar boat with 15 degree deadrise, well, let's just say I am not believing it. I have been expecting someone to step up to the plate with some actual figures here, but so far no one has.
Old 09-19-2007, 02:38 AM
Rep: 36 Posts: 73
I am not suggesting that it is 3% more speed. I am saying that in the most simplistic case there is 3% less lift. That might translate in 5 or 10% more drag or whatever. Which in turn might translate into more speed difference.
Old 09-19-2007, 04:02 AM
Previous Member
Rep: 0 Posts: 0
All other things being equal (unlikely) the deeper "V" will use around 7% more fuel. It will probably use more than this because you will be able to push it harder in rough conditions. Other factors that could outweigh the deeper "V"t o consider are overall weight and cabin windage.
The "V" is not the sole determinant of ride comfort and control but it certainly reduces slamming.
Normally a 26ft boat with a large outboard and fuel plus gear will sit near or below the chine at the stern so the deeper "V" does not alter at-rest stability too much. I remember the early Bertram hulls had a tunnel in the "V" that filled with water at rest. This was only in the 15ft hull to my knowledge and it probably floated higher than the chine if the chamber was not flooded.
Deep "V" hulls have a tendency to lean into cross-wind so it might need trim tabs to correct roll.
You should get some experience with you preferred hull in the intended conditions before committing. My information is a bit dated as I refuse to provide further support for fuel rich countries so use other forms of propulsion these days.
Rick W.
Old 09-19-2007, 05:13 AM
RANCHI OTTO's Avatar
RANCHI OTTO RANCHI OTTO is offline
Naval Architect
Rep: 512 Posts: 1,032
Calculate using Savitsky the bare hull resistance for a boat like this..
Lwl = 12 m
Bwl = 3.5 m
Lcg = 4.5 m
Displ = 8000 kg
Deardire = 15 deg or 20 deg.
speed range btw. 30 and 40 knota
SURPRISE...SURPRISE...
at 30 knots speed the deadrise 15 deg. has 6.6% less resistance but at 40 knots 6% more....
even if you modify the L.c.g. the differences are low...
Old 09-19-2007, 04:02 PM
Rep: 10 Posts: 16
Wow, thanks
I belive most models is calculated in calm water, but most of the time I will be in some waves riding with 25kn. I belive each wave for a 15 degree hull will absorb some energy where the 20 degree hull will make a "cut" as well as being more comfortable.
My hope is to have a mpg in the range 1,5-2 but is this realistic for a 20 degree hull, 26feet, beam 8 and and total load 2500kg and a suzuki df300.
The hull will have delta pad. I intend TIG welding below waterline and in level with hull and also be polished for best mpg. Any other good advise to consider for such a project.
Old 09-21-2007, 11:15 AM
Rep: 28 Posts: 512
Surprise indeed that a shape that generates less lift than another would achieve less resistance as the speed increases. Forgive my insubordination, but this sounds like a mathematical error to me. Please explain how this magic is made to happen.
If this is true, I believe that all the unlimited hydros would have deep V hulls. And the deeper the better, I'm guessing. And obviously they have nothing of the kind.
Old 09-21-2007, 11:48 AM
Naval Architect
These are results according to D.Savitsky..
The dynamic trim angle makes the differences...
Old 09-21-2007, 10:38 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
hmmm - unfamiliar concept
What is dyanmic trim ?
Old 09-22-2007, 04:16 AM
Nojjan Nojjan is offline
All thumbs...
Rep: 23 Posts: 104
Ranchi Otto - Would you mind declaring your calculation?. Apart from being rather odd values (LCG too far forward and the hull is too wide for it's weight, at least for a >35 knot boat) I can't duplicate your calculation. I do not get an intersection on bare hull resistance from Savitsky only based on the two deadrise angles.
Rwatson - Dynamic trim is the angle of attack for the theoretical prismatic hull planing on the water (normally taken as water surface to 1/4 buttock angle).
Old 09-22-2007, 07:54 AM
Naval Architect
Nojjan,
here they are the results of the calculation:
Deadrise 15 (20) deg.
vk 30 > EHPbh = 217 (231)
vk 40 > EHPbh = 367 (357)
concerning the dimensions of the "virtual boat" there are not far from an existing one.
Naval Architect
Nojjan,
16 Degree Deadrise mikey483 Boat Design 48 03-23-2007 06:47 PM
Difference in Degree Titles VillasRandy Education 7 03-08-2007 06:42 AM
Does Deadrise=Planing degree? willfishforbeer Boat Design 15 06-12-2006 05:56 AM
Degree.... Dave_raul Education 1 02-24-2005 10:03 AM
Masters Degree? Rizkie Abidin Education 1 08-09-2004 01:38 PM
