For a given deadrise angle there is an specific relationship between trim angle and lift coefficient which defines the inception of porpoising. Because of such porpoise considerations it is necessary to design the boat to operate at an unfavourable trim angle from the point of view of resistance, as the minimum drag-lift ratio occurs at an angle greater than the angle needed to avoid porpoising. The trim angle required to avoid porpoising increases with increasing deadrise angle. Increasing the deadrise enables a planning surface to operate at trim angles more closely approaching those required for minimum drag. So, it may happen a 20º deadrise brings better drag results than a 15º one at high speeds, if it risens the trim angle to a more efficient one from the point of view of the drag-lift ratio. I attach the well known 'Savitsky 64' paper. Cheers.
__________________ Guillermo Gefaell Gestenaval S.L., Naval Architecture & Marine Engineering Moon Yacht Design |
http://www.suzukimarine.com/boat_bui..._268_cc/df300/ I estimate your top speed will be around 37kts so a bit slower than the hull tested. Likewise a little more fuel at the various speeds. The tested hull is wider so should be a little more efficient. It has 21 degree deadrise so similar in this respect. Rick W. |
| Very good! This is half the information I was hoping to see. Now do we have similar data for a boat that has about 15 degree deadrise and similar length, beam, weight and the same type of motor? |
| 16 Degree Deadrise | mikey483 | Boat Design | 48 | 03-23-2007 06:47 PM |
| Difference in Degree Titles | VillasRandy | Education | 7 | 03-08-2007 06:42 AM |
| Does Deadrise=Planing degree? | willfishforbeer | Boat Design | 15 | 06-12-2006 05:56 AM |
| Degree.... | Dave_raul | Education | 1 | 02-24-2005 10:03 AM |
| Masters Degree? | Rizkie Abidin | Education | 1 | 08-09-2004 01:38 PM |
