| Did a dream got shattered? Although I made as many calculations as possible and it shows that the waterline has dropped, or otherwise said, the boat is lighter in the water. It is a pity that I haven't been able to come up with solutions to make the boat more stable. I could put more lead in both keels, which gives it a better center of gravety. I also could put more Sealed Lead Acid Batteries in the bottom of the hull. It would give me more energy. Absolute a pity. It had the right lenght, I could stand up in the cabin , it had all the detailed drawings for all the extra's I needed. It would not be the fastest and lightest boat on the water, but it gave me a solid , seaworthy boat. Detachable rudder, twin keel for the motors with rudder or reversal system build in. ( I cannot reverse the electrical motors due to the way the shaft is mounted to the pulley) The possibility to mount a small storm jib. If no positive suggestions will come forward from this forum, I will have to see what I can still do. Refer to the attachement Hartley4.jpg But it looks like I have to rely on the modified Fisherman, Firsherman.jpg. I have to crawl like an old man into the cabin, smaller boat than I like to have and one has two holes for the two single beds area, instead of one secluded nice spaced double bed like the Hartley above. No mast, not storm jib, no twin keels for stability. But it is light and that's all. For me to calculate the various calculations I need to do, nobody was willing to give a reply to : How can I calculate the wind forces by the various strong and weaker winds. i.e. what would be the force on a 1 square foot, or square meter 2 meter from a point in kgm or Newton or whatever. Bert |
| Am I understanding correctly that your problem is that this boat is not heavy enough?? She is riding too high on the water? Seems if I am reading this correctly, there are plenty of ways to overcome this problem. Most people have the opposite problem. |
| Always could take on more water, provisions, etc.
| is your problem that your not sitting at the waterline? couldnt you just add ballast? cement works good- steel etc...most boats need to be ballasted. dont worry you will solve it...good luck
__________________ I'm Master Mariner first! boatbuilder second! |
The problem is that I bought a plan for a 28 feet sailing boat and thought that I could modify the plans and reduce it by 13% However everybody stated that the boat would be unstable and I did my calculations and yes, it is indeed true what they say. Yes I could put some more Sealed lead acid batteries in the bottom of the hull and yes, I could start loading some more lead in the two keels. But I like the apealing view I made of the reduced sailing boat and yes, it is in my view more suitable on the open sea. However yes, it also means that the propulsion power I have avialable is limited. The Fisherman is certainly a better choice from that point of view. But I don't like the way two people have to sleep through two holes and also it is actually just too small. I thought it was a brilliant idea to reduce a plan by 13%, but like Tom and Easy and many other have said, it has become too unstable. My hope is, that after I have put the drawings I made on the boat.net, maybe somebody could come up with some ideas, we haven't thought about. Bert |
| Whatever you finally end up with I hope it carries you to a safer environment than the one you are in.
| This might be crazy, but now that you have figured out that the boat will be unstable if shortened by 13%, why don't you build it the same way the plans tell you to - at 100%? |
But it is not possible to drag those people away from their preconception, no matter how many experts comment on it. The real crux is, they waste their own lifetime and drag others into the same hole. Wasting the time in the boatshed, instead of bothering internet communities, people like him would have already accomplished half a boat to a proven design. ![]() |
Secondly, Apex1 Gruss Gott, I have done the calculations and you are right, it reduces the stability. But let me now ask you the question, you seem to know quite a bit about it. Let me repeat myself, there are no plans for a seagoing electric driven vessels, the size, the build, the shape, the comfort, the way I like it. Except to modify an exsisting plan. And I like the Hartley plans. COULD THE INSTABILITY BE COMPENSATED BY: a) making the 2 keels slightly deeper . Be carefull what your answer is, I will calculate the result. b) The orginal design has both keels straight down. Could the stability be improved by having them instead of straight down, at 90 degrees against the hull. With other words, the lower ends are pointing outwards. In that case I have to forget the rudders build into the keel, but I have to use the mechanical reversal method. Unfortunately, I will not dive into a shed and start making something , which is not what should be a succes plan, in which I have the confidence that it will work. Apex1, you have to do better than the remarks made. |
"For me to calculate the various calculations I need to do, nobody was willing to give a reply to : How can I calculate the wind forces by the various strong and weaker winds. i.e. what would be the force on a 1 square foot, or square meter 2 meter from a point, in kgm or Newton or whatever." Bert |
| I like to apologize to the readers. I have gone through most of the threads placed by APEX1, very few had some positive help, thus I cannot expect to get some sensible answer from him. I will ignore him in the future. May I ask the audience, are there tables, or thumb rule formula's to calculate the windforces on an object?? Bert |
But let me say that I have read this discussion (and the previous one, about Flareline 18) with some degree of curiosity, because it appears that you don't fully understand some important physics governing the boat design. You have recently discovered some elements of scaling thanks to mr. Lathorpe. And at some point you even wrote that you didn't know what a transom was before discovering it through this forum. Please correct me if I am wrong on that. Yet, you want to add frames, shrink/expand boat dimensions, modify the superstructure, modify the propulsion plant etc. of a design(s) you have purchased from that NA from New Zealand. This creates a conflict in what you would like and what you can do, imho. You would not like to spend big money for this boat, but you are seriously at risk of having to pay that money twice: the first time for a boat made upon plans modified by you according to advices taken here and there on internet forums, and a second time for a boat purposely and correctly designed for you by a person who knows his job (a Boat Designer). You say that there are no designs available for the boat of your dreams? Then why don't you make a detailed list of your requirements (a Statement of Requirements - S.O.R.) and hire an experienced person to design that boat the way you want it to be? You can also place that list here. I am sure there are many people here who would be willing to do it for you, but it has to be done following a logical path which starts from the SOR. The cost will probably not be so high as you might believe and will surely be less than the cost of two boats (or of one bad boat with a zero re-sale value...). Sorry for not giving you the so desired numbers which will allow you to build the boat... ![]() Cheers! |
For that reason I ask this audience, is there a way to correct this instability. If the answer is NO, not in your life. I will give up. But I am not willing to design a complete boat myself . I could be fiddling around with some boatdesign software, but I am not willing to do that, as I do not have the experience for that. We all know the rule, garbage in is gargage out. Although I have a reasonable knowledge of computers and electronics. Quote:
Just a naughty note. Preparing for a holiday is half of the fun. This is the same for making a boat. Bert |
| Bert, Here's the equation for calculating e.g. the wind resistance for a boat. The math for calcualting resulting force from the wind flow at a sail or a foil is different. Cd is reasonably constant for subsonic objects and depends on the shape. I use 0.3 because Rick Willoughby did, and it's similar to what I'm used to for projectiles with a blunt entrance. You can probably reduce Cd with better aerodynanic shape, but I don't think you'll ever get below 0.1. Erik F = 1/2 * air density * velocity² * Area * Cd Air density = 1.225 kg/m³ Cd = 0.3 approximately, depends on shape Area = Cross section area, m² Velocity = relative wind speed, m/s F = force, N |
Thank you Erik, I love it. I thoroughly enjoy it, when somebody comes up with solutions. Thank you very much. Bert |
| I Had A Dream... | Sean Herron | Open Discussion: All Things Boats & Boating | 7 | 01-25-2009 03:19 AM |
| A new dream | ebordier | Multihulls | 14 | 11-17-2008 07:58 PM |
| Help me to fulfill a dream | Carson | Education | 23 | 08-17-2007 12:43 AM |
| I have a dream - how to build it? | kach22i | Open Discussion: All Things Boats & Boating | 51 | 03-10-2006 01:18 PM |
| Dream Engines | Portager | Powerboats | 55 | 01-15-2005 05:25 AM |
