Old 01-14-2010, 02:49 AM
vinceUK vinceUK is offline
Rep: 34 Posts: 42
Diagonals on a line plan
Dear all,
this may seem as a stupid question but even after a few articles/chapters of books read on this, I am still a bit confused about how to draw diagonals on a lines plan.
They seem of primary importance but I don't know what they reprensent and how to draw them.
If anyone can help me on this, this would be very useful.
Sorry again if it looks stupid to you. Thanks by advance
Old 01-14-2010, 05:28 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
They are useful in fairing hull lines. There are no hard rules as how many or how to draw them through the section lines from centre line....
My 2 cents worth
Wynand
A scatterling of Africa
Old 01-14-2010, 05:43 AM
alidesigner alidesigner is offline
Rep: 93 Posts: 171
You start will an offset from centreline, say 200mm intervals, and then draw the lines at whatever angle suits. They were mainly used to get offset points for drawing full size lofts by hand. If using CAD you might not even need to bother with them. I havent bothered with them for about 15 years now.
Old 01-14-2010, 09:53 AM
Rep: 1758 Posts: 1,561
Diagonals are used for fairing the aft run or the heeled waterline, and as you surmise, are one of the primary lines of importance. I usually put a diagonal in as the 5th or 6th line (after the profile, waterline, and stations at bow, stern, and midships).
Diagonals should be placed approximately perpendicular to the shell in the area you want them to control. And because they are of such importance, they shouldn't be too close to each other or have any funky kinks in them, especially in modern transom sterns. In lofting, I generally recommend fairing to the diagonal in cases of conflict as this will give a more fair line.
Take at this water line, what do you think? gow153 Boat Design 5 11-04-2009 10:43 AM
Water line Devooo Multihulls 1 03-07-2008 04:42 AM
The Diamond Line... Sean Herron Open Discussion: All Things Boats & Boating 2 05-28-2007 10:55 PM
Line plan fiberglass boats 8 - 12.5meters TP-Mike Boat Design 6 11-30-2005 06:31 AM
Maxsurf: diagonals on flip side DaveB Software 4 01-30-2005 09:58 PM
