Old 08-12-2011, 04:29 AM
Laranjo123's Avatar
Laranjo123 Laranjo123 is offline
Naval Architect/Engr. FG
Rep: 17 Posts: 128
Determining yacht particulars
I would like to ask. Are there any formula in determining the length,breadth, depth of a motor yacht. or you any ratio values?..
Old 08-12-2011, 03:38 PM
PAR PAR is online now
Rep: 3125 Posts: 9,398
Nope . . .
Old 08-12-2011, 04:29 PM
braumab braumab is offline
Rep: 15 Posts: 2
In answer to your response...
That's a tough question to limit down ...
I did a little bit of research for you to make sure my answer wasn't wasting your time. I found that http://en.wikipedia.org/wiki/List_of...chts_by_length will give your lengths for just about any size you could probably want.
That's an interesting site I found. Anyway, for power vessels, the formula is length x breadth x depth over 100 x .67
...And for sailing vessels it is: length x breadth x depth over 100 x .50
I hope I've answered your question. All of this is assuming you have your length, breadth, and depth.
Old 08-13-2011, 08:17 AM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
That sounds like it might be a broad sweep at the prismatic coefficient. Not sure what it would be good for though.
Tom Lathrop
Old 08-20-2011, 03:18 AM
Laranjo123's Avatar
Rep: 17 Posts: 128
Gee thx though
Question guys? Are you all naval architects?
Old 08-20-2011, 04:27 AM
Stumble Stumble is online now
Rep: 599 Posts: 1,086
What you asked were what the formulas are to tell you how long a boat should be. Reality doesn't work like that.
You tell the designer what you want, and a price point and he determines the length based upon experience, comparable vessels, price, and a whole host of other criteria to determin what boat would work out well for you.
Old 08-20-2011, 05:26 AM
Sorry to be so flip Laranjo, but your question is so broad in scope, it's a bit like asking to know what the formulas are used to design a red car.
Old 08-20-2011, 08:02 AM
Laranjo123's Avatar
Rep: 17 Posts: 128
actually your right mr. par merchants ships have their own ratios. Unlike this yachts.\ In my own thinking i knew that this yachts doesn't have any ratios i mean it depends on how will be the owner wants his/her yacht to be like this like that. you are all right. This means my last bet is to get the info specs of the existing vessels and make a ratios out of them... ( correct me if i'm wrong?..)..
Old 08-20-2011, 11:05 AM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 576 Posts: 1,066
these are the ratios
Old 08-20-2011, 11:31 AM
I am not sure what ratios you are thinking of, or what they might tell you. Private boats run anywhere from 12 to 900 foot. Obviously there are more of the former than the latter and the richest people tend to have the biggest boats.
Within size ranges there are relationships between length and width, or depth, but only generally since a lot is driven by the specific design and intended use of the boat.
Old 08-21-2011, 12:27 AM
Making ratios for yourself is a noble if fruitless venture. They will not help you in any regard other then rational comparison. In other words you'd have to have several "qualifiers" to make any ratio list useful. By this I mean, lets say you're looking for an average beam/length ratio for a 30' sailboat. Well if you just take the B/L from the first 50 sailboats you encounter, it's not going to account for many "modifiers", such as triangular stern racers or relatively balanced ended CCA era yachts. The results of this B/L ratio homogenization would be meaningless. On the other hand if you subdivided the B/L list into specific categories, such as all out racers, racer/cruisers, cruiser/racers, light cruisers, medium cruisers, heavy cruisers, working craft, etc. then you'd have a marginal set of B/L ratios to work with, under it's specific category.
Laranjo, it might be more helpful if you just told us what you are attempting to do and/or ask a specific question(s).
Old 08-21-2011, 06:41 AM
Laranjo123's Avatar
Rep: 17 Posts: 128
All i want to know is are there any possible info about the ratios that are being used in yacht desinging?...Cause in my thesis what i've used was my parentship's ratios.... O__O
Old 08-21-2011, 07:35 AM
JRD JRD is offline
Rep: 137 Posts: 108
Read through Eric Sponbergs lecture notes on this site from a couple of years ago, he has analysed quite a number of critical ratios relevant to yacht design and how they relate to performance and safety. I dont think this is related to parentship data as such, but makes a very interesting read for the would be amatuer designer. (like me)
Larrson Elliason book gives a bunch of compatitive graphs showing ranges of relative dimensions and ratios which pertain to scale up/scale down of designs. As their perfromance writings focus on the delft models for drag etc, their book may be of interest.
I agree with PAR in that you will get better answers if you can share what you are trying to acheive in more than one line of text.
It may be a language thing, but your questions give me the impresion that you are a student that cant be arsed doing his research so jumps on the net every 5 minutes to ask questions, then assumes a correct answer from whoever will reply. Im sure thats not the case, but as a student of a proffesional engineering discepline you could consider making a bit more effort with your questions. You would not be employed for long sending out communications like that, if you worked in a real design office.
Old 08-23-2011, 09:04 PM
Laranjo123's Avatar
Rep: 17 Posts: 128
I see thx mr.JRD what you mean is i should detail my questions right?...
High speed boat particulars prasanna Powerboats 8 08-31-2011 05:12 PM
High Speed Ship Particulars prasanna Boat Design 0 05-04-2011 07:02 AM
Determining rudder torque Landlubber Inboards 12 03-09-2009 10:03 AM
relation between principal particulars pavel915 Boat Design 9 12-14-2006 10:52 PM
Determining draft ted655 Boat Design 25 02-09-2005 07:37 PM
