| OK - ya got me there! LOL |
| LOL!! Ted, You must see by now that things that seem so simple can be so complicated, or so simple. Your hull was easy and as mmd said my numbers are for floating level. Most hulls are strange shapes and may require the services of these pros. But most back yard builders will just build it and try it. Sometimes with interesting results. ![]() Gary ![]() |
| One big "DUH" on my part. Remembering about me not being a bright bulb. Thanks for holding my hand while we walked thru "he will get it eventualy land". Thanks guys |
| ted655 - Thanks for keeping the skin thick. ;-) It always helps. |
| Ditto. |
| the more rocker, the deeper she will float. sailboats tend to have more rocker than powerboats. rocker=bow & stern rise. |
| hello everyone, new member my interest is as follows: how much weight does it take to sink a 1`ft (12" inch) square block 1" inch in sea water. |
| About 5 1/3 lbs.
__________________ "The hand feeds the mind." Weston Farmer |
| larry so if i add all of the square footage of the bottom of my hull and calculate it by 5 1/3 lb. i can figure out how much weight i can put on the deck and know how deep it will draft, |
#25
| larry sorry about last reply , i should have said that the bottom of the hull is flat |
#26
| larry the hull also is tapered to the bow . |
| Draft Person Wanted - Antibes France | Services & Employment | 7 | 03-09-2006 11:36 AM | |
| fiberglass roll; determining length by weight and width? | GrantC | Materials | 5 | 03-07-2005 07:07 AM |
| Need to calculate the draft of a boat | tibett | Boat Design | 1 | 11-09-2004 04:07 AM |
| Altering shoal draft keel? | CaptK | Boat Design | 8 | 10-06-2003 09:54 AM |
| Immersion | Polarity | Sailboats | 16 | 02-20-2003 02:53 PM |
