| Determining capacity of a tank I want to know how many gallons of diesel my tank holds.The formula I have says L" X W" X H"= cu. in., divided by 231. When I apply this to known capacities of tanks in a catalog, I don't come close. Even allowing for strap indents & room for vapor expansion I'm always "almost" twice their ammouint. Anyone have a method of doing this , using simple math? Thanks ![]()
| lx hxw, in metres, say .6x.6x.6= .216 cu/m obviosly is 216 litres or in feet, 2x2x2 =8 cu ft 6.25 gals in cu feet, =48 plus, are you pulling our legs? |
| oh and that is imp gals, you will need to x .8 for US gals |
| Ted, For me it's simpler to work from cubic feet. 1 cu ft = 7.48 US gal. 1728 cu inches = 1 cu ft. So a tank 12" W x 24" H x 48" L = 13,824 cu inches, divided by 1728 = 8 cu ft, x 7.48 = 59.84 US gal. "max" capacity. 13,824 divided by 231 = 59.84, same answer. Working, or usable capacity can be as low as 70% of total volume, since there needs to be vapor headspace and the fuel suction tube is off the bottom of the tank. A conservative marine tank supplier will factor in an allowance for the suction tube's being fully submerged even during pitch and roll movements, so working capacity will always be significantly less than total volume.
__________________ Best, Charlie |
| Inches high times inches wide times inches deep, divide that by 1728, you get cubic feet. One cubic foot of water weighs 62 lbs. One pound of water is a pint, eight pints to a gallon, 62 divided by 8 makes 7 3/4. 7 3/4 gallons to the cubic foot. |
| And Charlie's gotten to it while I was writing. He had the actual weight of water, a bit less than 62 lbs per cubic foot. |
| yeah--- okay. You take the cubic inches, divide by 231, and you get the weight if water, not the gallonage. |
Hey Alan, I was working strictly with volume. 7.48 US gallons of water at "standard" temp will fill 1 cubic foot volume.One gallon of water = 8.33 pounds (I know, Stu, it's easier in metric ) and 7.48 gallons x 8.33 pounds = 62 pounds.Same, same, but I figured volume. My point is that working capacity will be less than volume. My head hurts. G'night all. ![]()
| Yes, I was serious, even if it is fall off the log for you .Thanks, I have more than 1 way now. Here is a sample of what I encountered' Sold as a 29 gal tank. 25.75 X 23 X 8 = 4738 cu. in. / 231 = 20.51 gal. (not close enough for me), where's the other 9+ gals? 14.5 X 14 X 23 = 4669 / 231 = 20.21 gal. (sold as 12 gal tank) again a 8+ difference, this time the other way. Here is another conversion that isn't close either. To Convert Multiply by To Obtain cu.in. ------- 0.00433 .---------- gal. Any how, thanks to all, I'll be able to figure my tanks now, so I know how much $$$ to borrow to fill them. $3.48 gal. on the Ohio river as of yesterday, ouch!! ![]()
And therein lies the rub--- I'll use 8.33 from now on. |
| X + Y = Z Where: X = Syphon out existing fuel Y = Filling up at Gas Station Z = Amount indicated on bowser What a genius poida |
| I am glad we converted to the SI a hundred years ago, or so ![]() |
its so simple, get a tape measure, measure it in mm, 100mm, = tenth of metre and so on. so 100 =.1m, .2 m =200mm, so its easy .5x .7x.3 the result=litres 105 3.8 l in one usa gal dont worry I,m absolutely useless at cad , but can do math , simple in my head, I also have many woman and boats in my head too ) |
| determining mast height | c&sautomarine | Sailboats | 2 | 09-10-2006 06:36 PM |
| determining distance between catamaran hulls | Thai | Boat Design | 4 | 03-31-2006 11:07 PM |
| Pontoon capacity | george allard | Boat Design | 2 | 03-19-2006 06:07 AM |
| Determining draft | ted655 | Boat Design | 25 | 02-09-2005 07:37 PM |
| Fuel tank capacity ,outdrive dependibility | ted Cichecki | Propulsion | 0 | 09-19-2004 10:39 PM |
