  #61
Old 12-05-2009, 06:57 PM
decoguy decoguy is offline
Rep: 25 Posts: 8
Originally Posted by lewisboats View Post
My suggestion would be quart milk bottles...they are square and can be corralled in nice square-ish shapes while minimizing the non-airspace in each bundle. I would net them in bundles. Put the clean empty bottles in the fridge or freezer and once the air is the same temp cap them tightly. This will keep them from collapsing until the temp gets below the temp that the air was originally trapped at. They will expand a bit as temps go up though. Make sure they are clean and washed out with bleach or something that kills bacteria, along with hot water. Now this stuff will last damn near forever...but you need to have a framework that will also last a long time...sealed PVC comes to mind. Cages of 1" PVC built to hold your mesh bagged bottles would work. The platform above could probably be of wood...or maybe that decking that is hollow plastic (recycled too). The cages would only have to be strong enough to contain the bottles but the framework for the deck would need to be beefy to support dirt, trees grass etc.
Unfortunately PVC is a big environmental no-no!
  #62
Old 12-06-2009, 03:41 PM
Boston's Avatar
Boston Boston is offline
Rep: 1360 Posts: 3,257
all plastics are a no no but pvc is likely the worst of all
I am skeptical of the deniers diatribe
Floating Pump Platform Design SWomack Boat Design 24 10-16-2011 03:13 AM
Russian Hydro-Foils for filling in commute bottle-necks? Squidly-Diddly Boat Design 5 08-27-2009 12:19 PM
How would a floating island be registered? JamesG Open Discussion: All Things Boats & Boating 12 08-03-2009 08:26 PM
cheap tubular swim platform / tubular platform supports Paul aka watertaxi Powerboats 0 07-08-2009 04:37 PM
About a floating island which the bottom is similar to barge. kilbysg Boat Design 48 12-12-2008 03:42 PM
