#61
| You've added a bunch of weight and windage up high.....this won't make the boat better...... Main thing I would do is drop the deckhouse until the sole beams just clear the top of the engine....she'll be much better for it...look better too...
#62
| Strongly reconsider you ideas on rearranging the scantlings for this vessel. The global implications could be catastrophic, without a much more careful understanding of their impact on the design as a whole. The raised bulwarks, particularly forward will offer some windage issues that I think you'll regret, but some extra HP will over come most of this. Oops, Tad apparently types faster then me. |
#63
| So does it need to be designed from the ground up for Cold molded? I'm not sure how much of an issue the weight is going to be. The C-Trawler series is mostly designed as sailboats, and Karl said the masts and booms would be fine. Aside from shuffling around some things on the interior I haven't changed the pilothouse at all. |
#64
| Spacers between wood and steel? | Conachair | Metal Boat Building | 3 | 05-19-2009 07:54 PM |
| Steel/ wood boat yard available in India | vishnubaiju | Boatbuilding | 2 | 04-27-2008 05:37 AM |
| Bending wood over steel frames..? | Omeron | Sailboats | 17 | 06-29-2007 04:36 AM |
| Wood or Steel? | axius0 | Materials | 12 | 09-21-2005 11:47 AM |
| Designing a wood epoxy classical boat. | Sailboats | 13 | 03-21-2003 05:42 AM | |
