#556
http://www.rocat.com/ There was considerable development on the design and construction and a few boats were produced and sold. I understand there was not enough interest to have a viable business. The boat is about as good as you can do with a catamaran but the performance against a rowing scull is relatively poor. About 11% slower or 35% more power to do the same speed. This is a fundamental of catamaran versus monohull as Leo L noted above in post #546. My figures are based on sustainable power for a fit person and total displacement of 114kg. The difference varies a little as design power and weight shifts. If there is a length constraint then the catamaran has an advantage below about 16ft for a single person rowed or paddled boat. The Rocat would be competitive against a beamier ocean rowing monohull but a few owners were expecting to be competitive against OC1s and surf skis. Paddles cope better with rough water than oars. A long monohull with pedal powered propeller is the most efficient human powered boat in any conditions. This clip shows the conditions where a beamy cruising pedal boat will outperform a rowing scull: http://www.openwatercycling.com/vidphotos/PICT0722.MOV A long slender pedalled monohull is even better than this as it does not pitch as much. Rick W |
#557
| The catamaran configuration provides extra stability allowing a sailboat to carry more sail for more power. With a human powered boat the amount of power is limited. An experienced rower (or paddler) can balance a narrow shell using the oars so the additional stability of a cat is of limited use to him. When the boat is powered by the legs which provide more power, extra stability is needed to handle heavier conditions hence a cat works best. Would a trimaran with small amas that can be above the surface much of the time be an even better choice?
#558
To clarify. Rowing with a rigger is more powerful as both legs and arms are in use. This is a feature of the ROCAT. I expect it gets close to the biomechanical efficiency of pedalling or paddling; both measured around 26%. A sliding seat sculler has been measured at 22%. Using both legs and arms in a coordinated way enables the highest power in anaerobic sprinting but pedalling is not far behing and requires less coordination. For longer duration, pedalling and paddling have similar biomechanocal efficiency but a good prop will give 85% efficiency compared with about 70% for a paddle. A pedal prop driven stabilised monohull is the most efficient for long distance and a pedal powered hydrofoil is the most efficient for sprinting: http://www.youtube.com/watch?v=0yk7t...3B10A6&index=2 http://www.youtube.com/watch?v=l2UOH65QOI4 Apart from the better efficiency from a propeller over a paddle or oar, there is also the advantage of steadier application of power with pedalling meaning that the fluctuation in speed is much less. A good recumbent cyclist will "spin" with about 30% variation in torque (and less variation in thrust) at slightly higher frequency than a kayaker and almost three time the frequency of a rower. The force in both paddling and rowing ranges from zero to a maximum and there is significant dead time at zero thrust particularly with rowing. Given the power is a cube function of speed, there is a significant penalty associated with speed fluctuation. Rick W |
#559
| So put your pedals and prop between the hulls and maybe (from an unqualified point of view) you have minimal drag , persistant power and if you add a bicycle gear system perhaps the potential to reach far greater speeds ? Though if i remember correctly this is a rowing competition we are talking about ? This guys sitting way too high but you get the idea . http://images.google.com/imgres?imgu...a%3DN%26um%3D1 |
#560
I speak from personal experience per attached video clip with pedalled cat v my numerous monuhulls; the comments of a ROCAT rower competing against monohulls and knowledge of the physics involved as quantified by a few extraordinary mathematicians. It is interesting that the developer of ROCAT did not realise the disadvantage would be so significant. In fact 11% is not all that significant if you are a casual rower but in competition it is a big gap particularly when you realise it takes 35% more power to achieve the same speed. Rick W |
#561
| A canoe like hull with a rowing machine , similar to those found in a gym , set up to power a prop , and 2 stablizers on out riggers ? |
#562
http://forwardface.com/includes/movi...teering_01.AVI His son may continue the endeavor. They were working on the stabilised monohull to lower drag at the time he passed away. The drive system is very efficient but still suffers the speed variation of rowing in the configuration shown in the clip. I used a pedal variation of the drive system using swing arms in my V12 boat. It has very high biomechanical efficiency but runs into problems at sprinting type power level. Rick W |
#563
| I'm way out of my depth here but what if the return motion was set to pull water and the power motion set to push ? or perhaps the return motion could be used as power also at a much lower gear ratio just to keep up momentum ? Just suggestions while trying to be helpful and probably worthless but they might possibly plant a seed in the mind of somebody who really can help ? I can't access the link you posted , it just says page can't be displayed ? |
#564
| Heres an idea that might be denied by our preconceptions about rowing , as we have no oars we don't actually need a full stroke , so what if we used 2 half strokes left and right to provide continueous power to the prop - imagine a rowing/running exercise machine ? |
#565
| Alternatively, if the power stroke is used to pull the seat forward and the legs to push it backward there are twice as many power storkes to harness for driving the prop.
#566
![]() http://www.duckworksmagazine.com/08/...kiff/index.htm |
#567
Rick |
#568
If you have a length constraint for storage or transport then this would be a good choice. Rick W |
#569
| design a convenient feature: *this boat can divided in two parts,it adds up to half the weight to manipulate,half the storage space,but twice the stability.And it can be put into the business car. *FRP boat,3 years warranty for the boat hull *PVC tube,can be attached & removed easily.But it can add safety and stability *more parts for the boat made of stainless steel,like oarslock,cleats on the bow and so on |
#570
The first person to suggest men could fly was locked up in a mental institution and i'm starting to know how he must have felt ! |
| Recreational light whitehall rowboat | mike1 | Boat Design | 9 | 09-22-2010 12:25 AM |
| no go fast | stuckinslowmo | Propulsion | 7 | 11-20-2006 05:06 AM |
| Rowboat design feedback? | John Larkin | Boat Design | 2 | 06-16-2006 04:14 AM |
| Carvel Plank Rowboat Leak Repair | Glennigan | Wooden Boat Building and Restoration | 2 | 05-11-2006 01:28 PM |
| sailboat=rowboat | zbernier | Fiberglass and Composite Boat Building | 1 | 08-23-2004 06:19 PM |
