| Designing a ballasted daggerboard I have a twentyseven foot sloop I built and designed. It is trailerable and henced only 8 1/2 feet wide. It has a ballasted daggerboard that originally weighed 1500lbs, last summer I added another a 300 lb bulb to stiffen it up. It is a steel fabrication filled with molten lead and coated and faired with epoxy. It is two feet wide and without the bulb it extends four feet below the hull. It is a NACA foil with a width to length of about 19%, is that a #2019? In any case I am thinking of replacing it mostly because so heavy that raising it is quite a chore. What I would like to do is replace the entire thing with a light weight fin with about an 1100 lbs bulb on the end. My calculations show that this would give the same righting moment and if I could keep the fin to a couple hundred pounds I could get rid of 500 lbs which would help a lot. I looked at the Melges 24 website and it has a 1100 lb bulb on a fin they say weighs only thirty-five pounds. My questions, I am sure I will have more, are what material do people think would be the most effective for the fin. I would like it to be a light as possible, although 35 lbs seems pretty extreme. And also is there any reason to use a thicker foil than structurally necessary. I.E. does it need to have a mimimum thickness to provide lift? Obviously the ultimately thinnest foil would be flat and the foil would provide no lift from its shape. I hope these questions make some sense and thanks for any advice Todd Miller |
Given a certain physical thickness that's set by the structural requirements, a high thickness ratio, like the 19% you mentioned, means a narrower chord to the keel and less area for the same depth. If you want to go with that kind of a thickness ratio, there are more modern sections that might be more appropriate. A section of modest thickness ratio will have a higher maximum lift than a very thin section. But extremely high thickness ratios don't necessarily continue that trend.
| Gybing Daggerboard? | Konstantin | Boat Design | 29 | 01-03-2005 04:07 PM |
| Daggerboard sloop? | mod flod | Sailboats | 3 | 10-09-2004 11:39 PM |
| Daggerboard position | miked12 | Sailboats | 6 | 04-12-2004 06:39 AM |
| daggerboard construction | Guest | Boatbuilding | 0 | 12-31-2003 11:44 AM |
| Help!!!! ( daggerboard construction or daggerboard design ) | 01639770993 | Boat Design | 1 | 12-29-2003 01:56 PM |
